Quote, originally posted by Daox »This is why I dislike using forums as a Bible for information. You all have semi-correct points, but not totally right. I'm not going to go over each type and how they work. You can go to the link below and it explains Honda's, Toyota's and other's cam timing/lift systems. Suffice to say VTEC is superior to VVT-I as far as performance goes. I-VTEC is definitly superior to both VVT-I and VVTL-I.Go hear to read about them:
http://www.autozine.org/techni....htmlThank you, you saved me the trouble in posting this.I have driven a SOHC VTEC engine, A DOHC VTEC engine, A SOHC iVTEC engine, and now my Trix with the VVTi. I have also driven a VVTLi engine in a camery, and I can tell you that VTEC is superior in all aspects. In SOHC form, VTEC was only affected the intake side of the process, so it helped but not to the full extent that DOHC VTEC could. DOHC VTEC would affect botht he intatke and exhaust cams so you had much more aggressive capabilities in regards to tuning. Also what was wonderful about the old VTEC (from 02 - 01 on various models) was with some engine management addons, like the Apex VAFC or the Hondata system, you could actually control when the switchover happened. Now in regars to the VVTL-i it is a good system, but you have to understand that Honda has been working with Variable Timing for MUCH longer than Toyota has, and has patents on certain designs which limits what other manurfacters can do.With my Old 98 Civic EX here was my setup in my old civic, and it was a BIG difference going from SOHC to DOHCBought stock - within 2 years added- DC 4-2-1 headers, AEM CAI, Skunk2 Coilovers with KYB AGX shocks, Venom ECU control module(allowed me to overide stock fuel maps) 50 dry shot nitrous. As you can tell, this was not enough for me. So, onto building the beast.In February of 2000, began my engine swap. (The only reason I had an LS tranny was that the GSR tranny blew and needed to find something fast. Ended up liking the LS tranny better as it provided MUCH better gas milage for highway driving and didn't sacrifice a lot during street racing. I could hang in certain gears longer than other GSR's but I had slower starts)2000 B18C1 (GSR motor) 1999 LS transmission(higher gear ratios),DC 4-1 headers, AEM CAI, Random Tech High Flow Cat, NEX coilovers, N1 Dunk Catback Exhaust with Custom 2.75" Piping and an ACT Extreme preasure plate with 4 puck disc(harsh, but it held up to a years worth of 6K rpm drops). Before I started pulling the engine apart to modify, I hit 155 on 635 near the Tollway with this setup racing a Turbo VW (only reason I lost is because my setup would not produce anymore power, and I was only at 5K RPM on an 8200RPM redline) At this time I was only puting down 190whp.After I cracked open the engine, I put in Skunk2 Cams with gears, titanium valve springs/retainers, Endyn Rollerwave 12:1 pistons w/ rods, bore from 1.8L to 2.0L with resleeve and P&P on the head and intake manifold. That yeilded 245 whp with 215lb tq. I then proceeded to the demise of that set of Rods and pistons by adding a GSR Plate Kit with a 100 shot. With the kit on, I could not keep the wheels from breaking loose through 3rd. Then I had to buy new axles since I snapped them at the track. Best time was 13.2 in the 1/4 before they banned me from the track for not having proper safety equipment (no roll cage) This was my daily driver. All mods came in 2000 and I drove that setup until 02 when I sold the car. Bought the car brand new for 17K (was a graduation present really) from early 2000 until late 2000 put close to 12K in mods into it. Engine had about 40Kmiles on it when I sold it, body had 125K miles. Sold car in late 02 (after LOTS of abuse from me) for $9,800 to a local kid who in turn promptly wrecked it within a week doing 90 in a 40. I cryed when I heard, that was my baby for so long.
