ModsWindow TintShort Ram ACT Extreme w/Street DiskFidanza FlywheelCustom Exhaust (Kept Stock CAT)Tein S-Tech"Special" Rims Possible Future ModA/F Gauge - possible fuel managementAnd that it - it is a daily driver after all, and I have Big project in my garage that needs some work.Before PictureCurrent
It should be fine, as long as it can still build the backpressure needed for the motor to run right. Its probably going to be only 2.5" that opens to 3" at the tail pipe. I need to do some more research first. I love Ohio, depending on where you live no E-Check
I wouldn't get rid of the cat. You risk major fines and getting the car impounded. I just read an article in the October issue of Import Tuner where they did a dyno test on a stock cat, two aftermarket cats, and a straight pipe. The straight pipe only netted a 5hp gain and a gain of 3ft/lb torque. If you went with the metal core Magnaflow OBD II cat, you would get an increase of 4hp and 2ft/lb. Ceramic core Magnaflow OBD II would get you 3hp and 2ft/lb. The metal core is if for if you are running a very rich a/f ratio. The ceramic would burn up under those condition. Basically, you can lose almost as much back pressure with a good aftermarket cat without breaking the law or harming the planet. (I'm not a tree hugger, but no sense in hurting the planet for a 1hp gain." They say that you can make up the 1hp and 1ft/lb difference that the straight pipe gives you just by dropping 10lbs. So cut off the head of your most annoying passenger, and you should be good.
Quote, originally posted by Navtrtl »I wouldn't get rid of the cat. You risk major fines and getting the car impounded...Not in FL, no emissions tests, ha!
“I live my life free of compromise, and step into the shadows without complaint or regret.â€
Viva la Pontiac! 2009 Jet Black GT
There may be no tests, but it is still illegal. FEDERAL EMISSIONS LAWS. You may never get caught if you use a bad cat, but not having a cat doesn't take a emissions test to figure out.
Quote, originally posted by Navtrtl »There may be no tests, but it is still illegal. FEDERAL EMISSIONS LAWS. You may never get caught if you use a bad cat, but not having a cat doesn't take a emissions test to figure out.You don't have to worry about me, my cat is still whole.
I don't mind if anyone removes their cat. It's theirs to remove. I just wanted to point out that you can get nearly the same gains from a good aftermarket cat as you can with a straight pipe. I'm sure the Magnaflow cat would cost less than the fine and/or impound fees.
I agree with what Navtrtl is saying. I'm not a big tree hugger either, but there's no point in hurting the environment for 1 to 2 extra hp. It's not a big deal to me if u take out the cat, it would just be hard for me to ever do that to a car of mine, knowing the damage that it would be doing to our environment.I dunno. Different perspectives I guess
Navtrtl and tcam,You both bring up Very good and important points. All very good things to consider. I'm not even to the Research phase of this little endevor and probably won't be for at least another year or so. These are the things that I'm going to look for. Depending on what I find going on with my A/F, my next project may end up being fuel management. Poluting is not my intent, and 1hp is definately not worth it. These are a couple of things that I won't have to search for when I start my research on this to Thanks for the input, a little less that I have to do now
Quote, originally posted by burkeyro »Navtrtl and tcam,Thanks for the input, a little less that I have to do now No problem. I try to help whenever I can. I don't really know enough to be helpful that often, but I try.
Quote, originally posted by burkeyro »Navtrtl and tcam,You both bring up Very good and important points. All very good things to consider. I'm not even to the Research phase of this little endevor and probably won't be for at least another year or so. These are the things that I'm going to look for. Depending on what I find going on with my A/F, my next project may end up being fuel management. Poluting is not my intent, and 1hp is definately not worth it. These are a couple of things that I won't have to search for when I start my research on this to Thanks for the input, a little less that I have to do now thanks. Have fun with ur modding
everytime i see your username i think of eeyore from winnie the pooh..lol...sorrryyy just had to mention this....dude i like those rims..where they from?
Quote, originally posted by waveresponder »everytime i see your username i think of eeyore from winnie the pooh..lol...sorrryyy just had to mention this....dude i like those rims..where they from?ROFLMAO - Nice. and I stole them from my buddy's SRT-4, Offset is a little bit off, but they work for me.
Quote, originally posted by Amtron »I'm likin your 'special' rims. What are they? and did you sell them with your Vibe?they look like rims from a neon or caravan
Quote, originally posted by burkeyro »ROFLMAO - Nice. and I stole them from my buddy's "Neon" SRT-4, Offset is a little bit off, but they work for me.hope that helps
Quote, originally posted by NascarXprt »hope that helps ...wow, I can't believe I missed that. Especially since it was the post right above me lol thanks Cole!
Yeah, I gave them back to my buddy, Gave he a brand new set of tires on them too. 225-50-17's They looked A LOT better with more meat on them then the rubberbands I was running. If you are serious about wanting them, I'll see if he is willing to sell 'em. Only thing is a couple of them got curbed a little. not too bad but annoying non-the-less.
