Tyre size
Zumbi
Tyre size
Post by Zumbi »
Can I put 215/60R16 tyres on my Vibe?
Raven
Re: Tyre size (Zumbi)
Post by Raven »
Welcome to Genvibe.Those tires are much larger in diameter and are not recommended. Your speedometer will also be way off.
Zumbi
Post by Zumbi »
pity. and what about 215/55 R16
Raven
Re: (Zumbi)
Post by Raven »
They are 1.7% different which is alright. The 215/60 were 4.9%. 3% is the recommended limit. Check here.http://www.1010tires.com/TireS...ubmit
Zumbi
Post by Zumbi »
ok. thanks a lot.
Sublimewind
Post by Sublimewind »
Welcome...!!!!You are from Moscow.... Vibes are getting to every corner of the globe it seems...!!!!I bet you don't see many..!!
manicdan
Post by manicdan »
go with 225/50 16s and u will see no difference except the tread wraps around the sidewall a bit, but thats a good thing
BlueCrush
Post by BlueCrush »
I had 215/60/15 tires on my Vibe earlier this year. There was no rubbing and the speedo was dead on. There were no drivability problem what-so-ever. My speedo was off by 2-3mph with my stock 205/55/16 tires. The 3% rule is a general guideline, not set in stone, and is not the same for every car, wheel or tire. You will be fine with 215/60/16 tires.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ramenboy...
Post by ramenboy... »
добро пожаловать в семьюi think there's at least a couple more vibe owners from russia on this forum. post pics of your vibe when you can!
de-badged o4 vibe
o2 triumph speed four
Raven
Re: (ramenboy...)
Post by Raven »
Quote, originally posted by ramenboy... »добро пожаловать в семьюYa, what he said!
