HID Conversion
Big_Red
HID Conversion
Post by Big_Red »
I did do a search for HID but didn't find anything, so I'm going to ask. I know the Matrix owners have made the switch, but what about Vibe owners? I'm looking for a place in the GTA (Canada) where I can purchase and get them installed at a reasonable price. Any help would be appreciated.
2003 Pontiac VibeSalsaPower PackageSports PackageK&N Air Filter
02csnow
Re: HID Conversion (Big_Red)
Post by 02csnow »
Just get in contact with KeithVibe. He can tell you everything you need to know. There are actually threads on here about HID's, you just got to find them.
Bye Bye Vibe.............
manicdan
Post by manicdan »
got some hids myself. from oznium.comi dont like them cause even if u get the highbeams working u still cant see anything but what the low beams would have shown you. and for 250$ i would have expected better. but hids alone are awsome light output and color.
Mrizzle05
Post by Mrizzle05 »
I actually have all the wires and ballasts and ignitors for a set of HIDs for the vibe, i just dont have any bulbs... : (And i might get rid of my car, so if you find bulbs i can get you the wiring kit for pretty cheap since its just sittin in the garage here. : )i had them on for a while and the output was amazing and they look sooooo good on the vibe.
keithvibe
Post by keithvibe »
Quote, originally posted by Big_Red »I did do a search for HID but didn't find anything, so I'm going to ask. I know the Matrix owners have made the switch, but what about Vibe owners? I'm looking for a place in the GTA (Canada) where I can purchase and get them installed at a reasonable price. Any help would be appreciated.You won't find ANY posts with HID, because you need four letters or numbers in the search.What you need to look for is 9003 or H4 hid kits. There are group buys now and again that you can pick up a set cheaper than buying them flat out. Because, the vibe has a bi-xenon bulb:most are a HID low beam Halogen high beam. You will pay more for the kit because of the extra bulb, usually 45-50bucks more for a halogen high beam/ 100-120 bucks more for a HID high beam depending on the kit.I have a halogen type of set up and I am sorry I didn't spend the extra money and get a HID lowbeam HID hidhighbeam.The set up Mrizzle05 is selling would work for you ONLY if you can find matching bulbs for his kit. NOT all bulbs are the same. It's usually paired with a ballast for use with their bulb and their bulb only. SOME, Mrizzle may be one of them that have used other manufactors bulbs with success, but you run the risk of burning out the ballast or bulb pre-maturely, and void any kind of warranty that comes with the set.Do a search under my user name, here and on matrix owners and you will find photos of my set up on my vibe, with before and after photos. I have a close up shot in my signature, both my fogs and headlights are HID.And if you don't know it already. The higher temp number, it ranges from 3000-12,000. 3,000 is yellow 12,000 is purple. If you looking for best visable light output, look at kits between 5,000 and 6,000.
ArcsVibe
Post by ArcsVibe »
Welcome back Big Red! Long time no see I have a seller in Toronto for HID's. I have a pair and they are amazing! Let me know...
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
manicdan
Post by manicdan »
arcs, can u go into more detail about the ones hes selling, cause i would seriously reconsider mine if i only knew what i was replacing them with
ArcsVibe
Re: (manicdan)
Post by ArcsVibe »
Here is his contact info: His name is Dave at sbisale@hotmail.com just tell him that Sam from the Vibe/Matrix GB from a few months ago sent you!Pictures of the HID box kit are here: http://forums.genvibe.com/zero...age=5He gives you a 1 year warranty on bulbs and the ballast and it is under 200$ Canadian shipped!
VOTM April 06
Big_Red
Re: (ArcsVibe)
Post by Big_Red »
Yes, it has been a while, but I'm back...Will e-mail and see what it is all about. I have someone here in the GTA as well, so I want to check it out before ordering.
joholste
Re: (Big_Red)
Post by joholste »
hey bud if you're looking to get some HIDs right now there is a GB going on over at MO
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
ArcsVibe
Re: (joholste)
Post by ArcsVibe »
Quote, originally posted by joholste »hey bud if you're looking to get some HIDs right now there is a GB going on over at MOIt would probably be cheaper and faster since the seller is located in his home province
VOTM April 06
Big_Red
Post by Big_Red »
I'll check it out. I know that they Trix uses different type of lighting (since they have seperate bulbs for high and low beams...
joholste
Re: (Big_Red)
Post by joholste »
he has the Bixenon HIDs for the Vibe...i'm in on a set of them.
