I looked into these, but by installing LED's in the same housing as your Headlight, you are voiding the warranty that superbirghtleds.com gives you. I am goign with the monochrome bulbs for the front of my car to get that cleaner look. From superbight website:Warranty Information Do not use LED bulbs in the same housing with head lamps, the heat will cause them to fail quickly and void the warranty.We warrant all of our bulbs for one full year when if used in normal vehicle applications.We do not warrant our car bulbs when used in applications other than normal vehicle bulb installations or if used in headlamp housings or to replace GM Day Time Running lights Some GM vehicles apply a pulsed voltage to the Day Time Running lights (DTR), this pulsed voltage causes LED bulbs to fail quickly, just as the stock filament bulbs also fail quickly in these DTR installations. Use in these applications voids the warranty.I am getting my LED's from this sitehttp://
www.frickinbrite.com/catalog/Going with their SMT 168 bulb for the liscense plate lights, SMT 921 red for the high mount, SMT 921 white for the reverse lights, 7440/7443 24 LED refractor in red for the Stop signal (dual intensity) and 7440 Amber 24 LED refractor for Rear turn signal.I was considering gogin with their SMT 24 LED for the tails and turns, but those are pricey.Also instead of buying and placing load resistors in line for each set of bulbs, just replace your flasher. The site above makes a replacement for the Toyota Matrix flasher (not sure if it is the same for the VIBE) but they do carry a wide assortment of flashers.
http://frickinbrite.com/catalog/index.php?cPath=62
