Got a little bored today. So i grabbed some pinstripping that was laying around and decide to put it on the car. I only had it on there for like 2 mins ( enough to take pics ). Just seeing what you all think. Should i put it on or just leave it off.
I like the end point.. not digging the start point... I think if you went back to your stock grill and gave me your billiet grill it would look A LOT better. HAHAHA
Quote, originally posted by keithvibe »I like the end point.. not digging the start point... I think if you went back to your stock grill and gave me your billiet grill it would look A LOT better. HAHAHADo you suggest something different for the back end. I was trying to get away from the every day pinstripping( straight ).
I like it going up the window. But, I think the front should go to a couple of inches before the side marker. It's unique which is always a good thing when done tastefully.
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
[QUOTE=keithvibe]I do like it around the back window... I may have to alter mine now. QUOTE]Copycat. Well if i do put it back on it will definitely go farther towards the front. it is only like that b/c i ran out.
leave it as is. but in the front have it angle up and follow the frame between the front windshield and doors. so it will be shaped like this: ______ but connected in the front(damn text limits)
