Any Common Problems with 2003 AWD's
MountainMax
Post by MountainMax »
I will be picking up my 2003 AWD Vibe August 17'th, and counting. It has 41000km on it. I was wondering are there any common problems/complaints for these models I should look out for or address right away? I see a few TSB's on them and the exhaust smell one I know will be an issue as the car does this at times, hope they will cover it under emmissions warranty.
.Fully Loaded 2009 Black Vibe 1SC with 2.4 Litre Manual TrannyCheck her out at My Cardomain page link below:http://www.cardomain.com/ride/3157869
BlueCrush
Re: Any Common Problems with 2003 AWD's (MountainMax)
Post by BlueCrush »
I would get the tranny fluid changed and the rear differential changed. Especially since you may not know how the previous driver took care of it.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
northvibe
Post by northvibe »
yup other than what BC said and of course the other normal maintenance done on it, there should be no issue. Just make sure to test drive and and that it shifts smooth.
MountainMax
you mean change the rear Differential FLUID ? or the diff itself? lolI will definately do both, im sure it was never changed before, thanks.
zionzr2
Re: (MountainMax)
Post by zionzr2 »
Quote, originally posted by MountainMax »you mean change the rear Differential FLUID ? or the diff itself? lolI will definately do both, im sure it was never changed before, thanks.Just the Fluid...Unless there happens to be a serious issue with the rear diff that would become evident durring a fluid change or test drive.Good rule of thumb with any used vehicle purchase is change all the fluids
BlueCrush
Re: (MountainMax)
Post by BlueCrush »
Quote, originally posted by MountainMax »you mean change the rear Differential FLUID ? or the diff itself? lolI will definately do both, im sure it was never changed before, thanks.LOL! Yeah, just the fluid. Haha.
My Fleet:
