How hard is it to replace a fog-lamp
cs1992
Post by cs1992 »
My driver side fog lamp was broken today. A rock flew up from the road as I was driving. I am glad it didn't hit the windshield!Has anyone else replaced a fog lamp? If so, is it difficult?
zionzr2
Post by zionzr2 »
Prepare for a giant sucking noise from your wallet.Those Fog lamps run around $150/ EACH.Then you'll want a set of Tool_Guy's Foglamp protectors.You also may want to choose to go aftermarket.Or check E-bay or slavage yards for a better priced OEM foglamp.
Whelan
Re: (zionzr2)
Post by Whelan »
#1 Go to the For/Sale Forum and pm MiVibeToolGuy and get a set of covers for like $20.http://forums.genvibe.com/zerothread?id=29137#2 Go to Ebay and pickup either a used one or a OEM remake for about $60-$70. Save yourself the $150 price tag, I have one and it is just as good as stock, identical actually.#3 Install and removal are easy, there is one screw at the bottom back of the lamp that has a nylon case around it. Just keep unscrewing it until the lamp loosens and pop the holding tabs on the side out. That screw also adjusts the height as well.
2012 GLI Autobahn 6MT
WaveAction
Post by WaveAction »
i think im gonna upgrade my fogs with piaa's and get toolguys protectors
Whelan
Re: (RedFire2K)
Post by Whelan »
I am replacing my lamps with another set of HIRs like I have in the low beams, you can do that for your fogs cause you use a 9006 like me.
