Scion TC brakes on a Vibe?
Fred Allen Burge
Post by Fred Allen Burge »
Hello, Wondering if TC brakes can be used on a Vibe. I have TC wheels on my 04 Vibe and was curious if the brakes would be useful for replacements or even maybe they would be an upgrade?Thanks,Fred
northvibe
Post by northvibe »
welcome to genvibe! that question I cannot answer... I am totally not sure if they use the same brakes :S The vibe does use the same brakes as a corolla or matrix though. So if you just wanted all disc then you could get a vibe gt brake set. The vibes stock brakes are pretty good already. even if you upgrade the rear (only base) drum brakes to disc they barely make a difference. Just make sure to have good pads and rotors in the front as they do most the work.
Fred Allen Burge
Re: (northvibe)
Thanks for the ideas, I'll look into the TC brakes and let you know if I find anything.Fred
~MRVIBE2006~
Re: (Fred Allen Burge)
Post by ~MRVIBE2006~ »
Just remember that the stock rims on a Tc are 17" (at least I think they are) so the rotors and calipers might require the 17" rim for clearence. Check before you buy unless you run 17" year round then you're fine.
2006 ABYSS VIBE: 20% TINT ALL AROUND FRONT & REAR SPLASH GUARDS MAGNAFLOW CAT-BACK EXHAUST GOODYEAR EAGLE GT (235/45/17) WITH TC WHEELS (SUMMER) DUNLOP WINTER SPORT M3 (215/55/16) ON STOCK ALLOYS (WINTER) AUTO VENTSHADE WINDOW VENTS PLUS SUNROOF VENT K/N AIR FILTER,OTHER DRESS-UP GOODIES...
