Anyone know what the HP and the torque gains are for a C.A.I.?
Windoze: When you absolutely don't care enough to buy the very best!/liberalism“The dustbin of history is littered with remains of those countries that relied on diplomacy to secure their freedom. We must never forget... in the final analysis... that it is our military, industrial and economic strength that offers the best guarantee of peace for America in times of danger.†—Ronald Reagan
Not much.... 3-5 maybe... It's more about it working with a system, like adding headers and exhaust... I wouldn't expect much, except for a little pep...
Like sublimewind said, but depending on the brand I'd say 5-8hp, but you will lose low and low-mid range torque. However, you will gain a little more torque at the higher rpm range.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by djb383 »Pretty close to zero in the 2500-3500 rpm range where you drive 99.99% of the time.But when you get on it (with header and exhaust) the power comes on like a motocross bike from 3,500rpm and up. Isn't that when you want the extra power, when you are winding it out WFO.
I believe the original post was about a CAI. There have been dyno results posted, after installing a CAI, showing little, if any increase, from 2500-3500 rpm but 3-5 HP increase at 6300-6500 rpm (base redline). Don't recall seeing dyno results after a header and exhaust install but it would be interesting. For sure the noise level gets a boost.
Quote, originally posted by Sunny »But when you get on it (with header and exhaust) the power comes on like a motocross bike from 3,500rpm and up. Isn't that when you want the extra power, when you are winding it out WFO. Umm 5 hp is about the same difference as having a mid size dog in the car with you. And since the 5hp is at peak powet, the % difference is and feels very small. There's actually less power below 3K and you feel that more because the percentage of loss down there is much greater.
a GT will have different results from an AWD or base. driving the demodded pumpkin (04 Vibe 5spd), i notice a huge performance difference in the 3500 K rpm range from when we had CAI, Exhaust and Unichip. even without the CAI and unichip, the exhaust made a slight difference. and the other day, forgetting that i was in the Pumpkin and not my usual DD, and that we demodded the vibe, i almost got ran over by a volvo wagon! would not have happened with the mods on the car.
Quote, originally posted by goodvibe » Umm 5 hp is about the same difference as having a mid size dog in the car with you. And since the 5hp is at peak powet, the % difference is and feels very small. There's actually less power below 3K and you feel that more because the percentage of loss down there is much greater.How much horsepower does a Unichip deliver for $500.00 compared to a $100.00 CAI? 25HP, me no think so.
I might as well chime in.The CAI itself adds only a few horses on it's own.But with a cat-back and/or header seams to make it worth it.I did notice a drop on the lower end,but much better on the top end,especially on the highway.Then I added the unichip and gained my low end torque back and it seemed to add more all around.But I got bored of that and added a supercharger.Much better now.
Quote, originally posted by Sunny »How much horsepower does a Unichip deliver for $500.00 compared to a $100.00 CAI? 25HP, me no think so. I got the unichip because it added as much peak power as an intake but actually showed the most difference where a GT is weak. Below lift. Much better drivability and pull down low. To each his own. It made enough of a difference that a freind who drove it a few times knew it had an upgrade the first time he drove it with the chip and without being told. I can also afford it and wouldn't consider another GT without one. Buy your next stereo by looking at #s and you'll get what you deserve. Your's is a small minded view unless you've tried it.
