Ram Air
Stealth_Vibe
Ram Air
Post by Stealth_Vibe »
question on ram airif you want to have a ram air hood do you have to have a short ram air intake or a CAI.if you just have the hood does it do anything by its self.
2005 Vibe GTpower group, moons and tunesdoor sils, injen cold air intake dress up kit, chrome accents wipers pedals shift knob "T.ha H.ate U. G.ive L.ittle I.nfants F.u**S E.veryone" THUG LIFE
djb383
Re: Ram Air (Stealth_Vibe)
Post by djb383 »
It doesn't really matter what type of intake you have as long as the ram air hood is sealed (when closed) to whatever type (including stock) of intake you have. That's the trick, sealing the hood to the intake.
Raven
Post by Raven »
The ram air hood does nothing but look good by itself. If left open it will cool the engine bay a little. If hooked up to the intake it brings in cooler outside air for a small horsepower gain. If you are going 100mph+ then the ram air effect will begin to produce additional HP.
northvibe
Post by northvibe »
The two ram air hoods I have seen route the ram air vents to the top of what would be the stock air box. If you had a SRI there then yes it would route the air to that air filter. As for noticable increase in performance...not sure, but it would bring some cooler air to the filter and engine bay.
djb383
Post by djb383 »
The bottom line is, if you can't seal the air scoops to the intake, you have nothing more than CAI. By sealing the scoop(s) to the intake, a slight air pressure increase will occur inside the intake as vehicle speed increases. If the scoop(s) are not sealed to the intake, then under the hood is being filled with cooler air, which is better than nothing, but it ain't ram air.
northvibe
Post by northvibe »
oh yeah, most the ram air stock hoods have that rubber seal around the air box part...which could be do-able with the stock vibe air box and the ram air hood.
djb383
Re: (northvibe)
Post by djb383 »
If the factory air box is used, the scoop(s) must be plumbed into the bottom half of the box for air filtration.
satur9
Re: (djb383)
Post by satur9 »
the slp hood comes with a cone filter that goes over the inlet .then some other stuff to seal up the stock airbox.
djb383
Re: (satur9)
Post by djb383 »
Yep, that sounds like SLP is doing it right. Like I said, if the scoop(s) are sealed to the intake, you have both ram air and cold air - no seal, cold air only.
Stealth_Vibe
Re: (djb383)
i hate to answer a question with a questionbut if i buy a CAI from whatever companyand i then buy a RAM AIR hood from some other companywill the ram air hood come with the seals i need to seal the hood around the CAI
kevera
Re: (Stealth_Vibe)
Post by kevera »
No
djb383
Re: (kevera)
Post by djb383 »
Quote, originally posted by kevera »No
Whelan
Re: (djb383)
Post by Whelan »
All the ram air you could ever need
2012 GLI Autobahn 6MT
NUBlackshirts
Re: (Whelan)
Post by NUBlackshirts »
Yeah, except I think it only works going backwards.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
Whelan
Re: (NUBlackshirts)
Post by Whelan »
Did you see that bucket of beans!!! He has to have a big mouth to inhale from.
djb383
Re: (Whelan)
Post by djb383 »
That's not ram air, it's zoomie exhaust. Hope there's a fire extinguisher close by.
