Just in case you need a laugh: Remember it takes a college degree to fly a plane, but only a high school diploma to fix one.Reassurance for those of us who fly routinely in our jobs.After every flight, UPS pilots fill out a form, called a "gripe sheet,"which tells mechanics about problems with the aircraft. The mechanicscorrect the problems, document their repairs on the form, and then pilotsreview the gripe sheets before the next flight. Never let it be saidthat ground crews lack a sense of humor.Here are some actual maintenance complaints submitted by UPS pilots(marked with a P) and the solutions recorded (marked with an S) bymaintenance engineers.By the way, UPS is the only major airline that has never, ever, had anaccident.~~~~~~~~~~~~~~P: Left inside main tire almost needs replacement.S: Almost replaced left inside main tire.P: Test flight OK, except auto-land very rough.S: Auto-land not installed on this aircraft.P: Something loose in cockpitS: Something tightened in cockpitP: Dead bugs on windshield.S: Live bugs on back-order.P: Autopilot in altitude-hold mode produces a 200 feet per minutedescentS: Cannot reproduce problem on ground.P: Evidence of leak on right main landing gear.S: Evidence removed.P: DME volume unbelievably loud.S: DME volume set to more believable level.P: Friction locks cause throttle levers to stick.S: That's what friction locks are for.P: IFF inoperative in OFF mode.S: IFF always inoperative in OFF mode.P: Suspected crack in windshield.S: Suspect you're right.P: Number 3 engine missing.S: Engine found on right wing after brief search.P: Aircraft handles funny. (I love this one!)S: Aircraft warned to: straighten up, fly right, and be serious.P: Target radar hums.S: Reprogrammed target radar with lyrics.P: Mouse in cockpit.S: Cat installed.P: Noise coming from under instrument panel. Sounds like a midgetpounding on something with a hammer.S: Took hammer away from midget.
GENVIBE: THE PLACE WHERE ALL THE COOL KIDS HANG OUT05 GTK&N SRI, exedy clutch, fidanza flywheel, Neo-GensLIFT: the equivalent of viagra for your tach n speedomy garagehttp://forums.genvibe.com/zerothread?id=24931
Kinda makes me wonder how true they are. Working in a service where I deal with workorders that say stupid things, and I always want to put down smart (removed) remarks... god bless the workers out there that have the balls to say what we all want to, lol
