Powerslot Plus rotors?
DopeVibeGT
Post by DopeVibeGT »
Did a search and didnt see anything. Anyone get the bigger brake kit from Powerslot? I'm thinking of getting them and just wanted to know if anyone has them and could unlighten me on how good they are.
Pictures of my ride!!'03 Vibe GTMy AED GA!Work in progress
Vibe_dude
Re: Powerslot Plus rotors? (DopeVibeGT)
Post by Vibe_dude »
Don tknow ablout powerslots.....but i have Inroble's on mine and wow these puppies sure do stop on a dime..and give ya some change back.
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
Sublimewind
Post by Sublimewind »
I donno about a big brake kit, but you might wanna look at what FrozenRotors.com has to offer... http://www.frozenrotors.com/se...ex=14
Sublimewind
Powerslot Big brake kit.... Vibe GT..http://www.buybrakes.com/power....html
DopeVibeGT
So, I take it no one actually has these? Guess I may be the first.
Whelan
Re: (DopeVibeGT)
Post by Whelan »
I have the Powerslots and they are incredible, used them on my last 3 cars. As far as the powerslot plus. Alls it is is a larger rotor that uses your existing brake calipers. It has an extender to push them out so it all fits fine. They offer no additional stopping power than the traditional powerslot, it is akind of a faux big brake kit that gives the appearance of bigger brakes.Also notice the footnote on wheel size and space needed to install.
2012 GLI Autobahn 6MT
prathman
Re: (Whelan)
Post by prathman »
Quote, originally posted by Whelan »Alls it is is a larger rotor that uses your existing brake calipers. It has an extender to push them out so it all fits fine. They offer no additional stopping power than the traditional powerslot ... Why not? If the rotor is a larger diameter and the pads are moved out then they should have greater leverage to stop the car. In addition, the larger rotor surface should be able to dissipate more heat. I don't personally have any interest in them since I don't want to go to a larger wheel size, but they seem reasonable for someone who likes larger rims.
Whelan
Re: (prathman)
Post by Whelan »
TrueFrom the powerslot site:The Power Slot Plus system uses a larger diameter, premium quality Power Slot brake rotor combined with your original factory brake calipers. Our patented caliper relocation brackets space the factory caliper further away from the hub to accommodate our oversized brake rotor. This increases brake torque force without affecting pedal effort or travel. The larger rotor is also a more effective heat sink, absorbing the heat generated under heavy braking. This greatly reduces brake fade and provides consistently shorter stopping distances, especially from higher speeds. NOTE: All Power Slot Plus brake kits require the use of larger diameter wheels. Check the dimensions of your wheels carefully before purchasing.
manicdan
Post by manicdan »
ok off topic just a bit, i have an 05 GT and its not on their list. i also know that i have disc in the front and back, and my hand brake is a drum style hidden inside the rear brake rotors. is the 03-04 like that as well?
CountryVibe
Re: (manicdan)
Post by CountryVibe »
For the GT's you need to look at the Matrix XRS, it's all the same parts except the body
2005 GTmoons & tunes, keyhole covers, SRI,2.5" borla catback exhaust, seatbelt beep deletedWagons Rule.......Sedans Drool
Whelan
Re: (CountryVibe)
Post by Whelan »
Powerslot PlusTraditional Powerslot RotorTaken from http://www.powerslot.com
satur9
Re: (Whelan)
Post by satur9 »
i think aem bought powerslot or vice versa. if you check on newcelica.org you see all the people complnaining about uneven pad wear from poorly designed relocation brackets.this is only true on the bbk's that use the stock calipers and at the time aem was pretty much the only person selling them.if you have aftermaket rims triple check clearance.
Whelan
Re: (satur9)
Post by Whelan »
I don't think Powerslot has been bought out, they may have just introduced the item to compete with AEMs kit as an alternative. Plus keep in mind that Powerslot recommends Hawk pads for their rotors (why I have no idea, Hawk HPS especially are crappy IMO). But I would think if they were in cahoots that they would be sponsoring each others products somehow.
