Just Bought an 03- What sounds are these?
gillham
Post by gillham »
Hi all, This is my first post. I just bought an 03 baseline Vibe with 64k on it. I test drove it and had it checked out and everything seemed fine. However! The day after I bought it I left for a trip and came back 4 days later.The first drive was terrible. A gargling sound came from the engine when I put it in reverse and then continued as I drove around 20-30 around the block. Since then I've noticed the sound returns after it has been sitting overnight.Once the car has "warmed up" (shouldn't really be needed here in Texas), it drives really smooth.Any ideas on what this could be?Oil is good, but I'm 200 miles away from a change. Trans fluid is good.Thanks,Matt
moongdss
Re: Just Bought an 03- What sounds are these? (gillham)
Post by moongdss »
Welcome to Genvibe! I haven't a clue what the sound could be, but the good folks here will have plenty of suggestions for ya soon.
Pandora the 2006 Pontiac Salsa Vibe, 17"wheelsMods: tint, "Pandora" windshield decal, front badge skull overlay, rainguards, hoodguard, Projectorz headlite covers, black painted grills, FIAMM dual-tone horns, black grafxwerks overlays, redouts, Genvibe decals, splashguards, scangaugeII, 12v console outlet, DRL interrupt and I turned off that @#$% seat-belt beep! upcoming: red interior LEDs
northvibe
Post by northvibe »
welcome!hmmm you should start the car put it in reverse and when you hear that sound, put it in park and leave it running, pop the hood and then poke around in the engine compartment to try to figure out what part is causing that. could be coolant that is low.....
Digger
Re: (northvibe)
Post by Digger »
How many miles are on it. It could be the front brake pads
Digger
Post by Digger »
zionzr2
Post by zionzr2 »
Welcome!! To Our Vibedom!!I will be moving to Austin in August!I you get the sound issues solved soon. Yeah Coolant level check also check the A/C drain tube for blockages
ToolGuy
Post by ToolGuy »
Yeah what Digger posted, check your belt!
coldmm803
Post by coldmm803 »
welcome to the board
ajflan
Post by ajflan »
Welcome to genvibe. I'm not sure what that sound could be.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
johnnymac
Post by johnnymac »
The sound could be a bad belt tensioner. The sound comes and goes at different speeds and thus rpms. Just a thought.
melders
Re: (johnnymac)
Post by melders »
welcome to the site!
2009 Pontiac Vibe GT - Jet Black Metallic
Sublimewind
Post by Sublimewind »
Hi and welcome!Gurgling sound, like WATER gurgling? If so, check your coolant, you could be low. My Subaru does this all the time, but i know what that problem is.... Do you get a "water" wooshing sound when you rev the engine in park?
