Remove Rear Taillamp Lens/Housing 2006 Vibe
Justme
Post by Justme »
Anyone know the secret to remove the right rear lamp lens unit in a vibe? I have thereplacement part but can't figure out how to remove the damaged lens housing.Here's the part I'm speaking about.
NascarXprt
Re: Remove Rear Taillamp Lens/Housing 2006 Vibe (Justme)
Post by NascarXprt »
if you go in the back of the car, there is a compartment on the side right behind the tail lamp inside the car, remove the cover and there shows three screws and nuts, there is a white clip that is holding some wires, it just clips off and if it breaks no biggie. hope this helps, if not then i can go out and take a pic for you.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Justme
Post by Justme »
Thanks for the quick responce. Thw problem is that I look inside the compartment and don't see any screws. Now I'm wondering if I need to remove the entire panel inside the hatch area.What year Vibe are looking at?
kevera
Post by kevera »
It's easier to remove the panel.
Justme
Post by Justme »
So now how does that come off?
kevera
Re: (Justme)
Post by kevera »
I stand corrected,Nascarxprt was right.You have to shove your arm up threw that access cover.Feel around for the bolts.You will need a wrench to get at the nuts.
kevera
Re: (kevera)
Post by kevera »
It's a 10mm wrench,and don't drop your nuts.lol
kevera
Re: (kevera)
Post by kevera »
Or if you want to take the long route,here is how to get at it.I did this quick so,- remove the false floor, the nuts are in the tracks near the hinge- remove the tire tray insert, just unscrew the grey thing that holds the tray down and pull it out- Take out the cover over the other cargo box and unbolt everything in there and lift it out- pop out the quarter panel insert on the side and just gently pull on it by the edges, it will pop out. It's just held in by clips- reassemble the cargo area in reverse order.You don't have to remove the spare tire.
NascarXprt
Re: (kevera)
Quote, originally posted by kevera »Or if you want to take the long route,here is how to get at it.I did this quick so,- remove the false floor, the nuts are in the tracks near the hinge- remove the tire tray insert, just unscrew the grey thing that holds the tray down and pull it out- Take out the cover over the other cargo box and unbolt everything in there and lift it out- pop out the quarter panel insert on the side and just gently pull on it by the edges, it will pop out. It's just held in by clips- reassemble the cargo area in reverse order.You don't have to remove the spare tire.hahaha yea that is the reeeaallll looonng way. but yea you have to feel around to find them. stupid little compartment back.
Justme
Post by Justme »
Easy when you know how to get the old one out. Thanks to all the job is done. Can't imagine how much a repair shop would have charged for that 5 minute fix...
Shadow-Vibe
Re: (Justme)
Post by Shadow-Vibe »
They would have charges for a 2 hour job. HAHAHAHA No offense to all those mechanics out there
