weird clicking sound???
Ninja_Logan
Post by Ninja_Logan »
My Vibe is making a clicking sound randomly every once in a while when i start accelerating or when i coast around corners at like 10 or 15 mph. its definately coming from my front end but im not sure if its a blet or transmission or suspension. anyone have the same problem or know what it is?
northvibe
Post by northvibe »
it could be something with the brake. My old sable had a piston that wouldnt work correctly and would not release right. It could also be a CV joint issue, or tie rod. Try pushing on that side of the car when its just off and sitting to see if its suspension (quick check). Some other members are going to know something too..
Raivis
Post by Raivis »
from info you have given my first guess would be cv axle. check and see if any boots are busted open. does it do it at higher speeds then 10-15???
You got owned by a wagon..... Life is a sexually transmitted disease!!! check me out at http://www.myspace.com/raiviskysdad
Ninja_Logan
Re: (Raivis)
no its strictly when i start to accelerate and at low coasting speeds.
kevera
Re: (Ninja_Logan)
Post by kevera »
Are your lug nuts tight.A loose wheel will cause that sound also.
Ninja_Logan
Re: (kevera)
that was what i first thought, but i went and tightened them all and it still has that sound
JesseWHHS
Post by JesseWHHS »
this started with my vibe a few short days ago! its constant though. if u turn off ur stereo and AC. stick ur head out the window. u can hear it. lol. but its REALLY noticeable at lower RPMS and low speeds cause less noise to interfere. My vibe is currently in the body shopI told the body shop dude this afternoon when I went and took these pics, and he said in the morning they will look and see what it is. I told him it drove the same, just made that awful clicking noise. He told me he is pretty sure its the belt or tensioner. I just hope to god he is right. lol. BTW I took in my Vibe this morning at 8am, and will be getting it back at 5pm tomorrow. KICKASS. and the guy saved me from having to pay my deductible.
2003 Vibe with a 2006 Corolla Engine 16" alloys with Fuzion HR-i's on emred neon underglowtinted; 35 on 4 doors, and 15 on back 3 windowsBosch Platinum Fusion +4 spark plugsmoon and tunes package15" Kicker CVR in kicker ported box with Rockford Fosgate P5002 amp
Ninja_Logan
thats sick. just let me know what ya find out
JesseWHHS
Post by JesseWHHS »
well I went and saw the guy today. He is talking to the Pontiac dealership where I got my car, and the guy says he is looking for recalls or any common problems that would cause this. There was nothing wrong with the belt or tensioner they said. So I don't know, I was hoping it would be a quick easy fix...I guess it could still be, but not sure yet. Im supposed to call him in an hour and a half to find out whats up. When ever I find out what is wrong I'll be sure to post back.
redlava
Re: (JesseWHHS)
Post by redlava »
This may sound stupid, but it might be something as simple as a rock in the tire.
Petrucci914
Re: (redlava)
Post by Petrucci914 »
You can usually go and pay $20 to have a total axle inspection. I'd do that. It's possible a CV boot is torn and rocks/dirt have entered.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
DavidPIL
Re:
Post by DavidPIL »
Heya...in 2004 I started experiencing a clicking sound which seemed to come from the rear driver's side though on occasion, it seemed to come from the front passenger side. Brought it in to my Pontiac Dealer... they found nothing and charged me $39 to check - Went to a place then soon became my new tire place, they heard it but suggested I go to GM in case it was a warranty issue. Since my Pontiac place already charge me, I decided to tackle it myself, sorta.I noticed the piston on my rear caliper was loose. I could push it in about 1/8" then it would just sit there freely. Bled the brakes and Presto... the clicking stopped. My clicking mainly occured at a very slight press of the brakes then sometimes continued on once I removed the brakes. The assumption was that the rotors were very slightly warped causing the brake pad to catch and release as that warped part went through the calipers. Bleeding the brakes fixed the "play" in the pad thus ending my problem. This might help you as well...Dave
JesseWHHS
Post by JesseWHHS »
well i know its the engine. i pop the hood and manually rev it, and it clicks there. the otehr day i went to check on the car at the shop. the guy told me there is no oil in my car..... I dont know (removed) that is about. lol. I get it changed every 3000 miles. Anyway he told me its the timing chain tensioner. It is operated by the oil pressure and since there is NO oil, it cant operate correctly.Any idea how the oil went away? lol. There are no oil spots in my driveway or any of my normal parking spots. The engine never got hot, the needle always started at cold and went until it was straight up and stopped there.They are gonna finish the paint and stuff Monday. Then when that is all complete, they will put it on a lift and make sure what they said was true. They are gonna look at all of this for free, but if its anything major, they are gonna make me pay for it.
redlava
Re: (JesseWHHS)
Post by redlava »
It's good that they may have found the problem. It's usually a good idea to check the oil level whether or not it is using any or not. Sometimes the only symptom of low oil is the engine locking up. But good luck and hopefully it is an easy fix.
JesseWHHS
Post by JesseWHHS »
well.... paint isnt right he said, so they are gonna respray the car today. anyways he told me today, he thinks its a sensor that does sumthin with the overhead cams. He thinks it is stuck or broke. I dont know yet, he is supposed to know all this stuff for sure tomorrow. I go meet him when i get off work around 12. Then I will be face to face with him and get the real deal.But until then im driving my dad's 86 el camino SS. hehe. it sucks down gas but it sure sounds good with its flowmasters on it. lol
Vibe_dude
Post by Vibe_dude »
mine makes the same sound...mostly when u put it in gear..or reverse.or accelerate quick.but i know what mine is.I had the belt tensioner replaced last year.but it get at it the upper engine mount had to be take off.....and the enegin lifted a bit out of place......but I think it cased the cv joint to come out of place a bit...now it clicks at the drivers side wheel hub.....check and see if that is where it is comin from...could be the same prob.
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
Ninja_Logan
awesome thanks ya'll! im getting my oil changed tomorrow so hopefully that will fix it. cuz i havent done anything to the engine yet its all stock, so hopefully its the oil.
JesseWHHS
Post by JesseWHHS »
well my car is out of the body shop for a week. it wasnt the BEST work so they are gonna fix a few things I dont like. Currently its at a shop that a neighbor owns. They are gonna look at it tomorrow and let me know whats up. I hope they figure this crap out and let me know. haha. Now its a REAL mechanic and not a body guy guessing about stuff.
Ninja_Logan
Thanks Ya'll! got my oil changed today and it isnt clicking anymore! im a happy Vibe owner
JesseWHHS
Post by JesseWHHS »
they suggested i change my oil and flush it. Well after doing that, spending another $50. SAME EFFIN PROBLEM. so now they are taking a look inside the Vibe's engine. . I should know in the next few days what is going on and how much it will cost to get it fixed. As of right now, I owe the shop $150 and nothing is even fixed. haha
JesseWHHS
Post by JesseWHHS »
update: they have been looking for a few days, but they cant find anything wrong. (removed)? haha
Petrucci914
Re: (JesseWHHS)
Timing Chain hitting the cover?
JesseWHHS
Post by JesseWHHS »
prob not, but ill call them tomorrow and suggest it. Im sure he has already looked, but ill make sure.
VforVIBE
Re: (JesseWHHS)
Post by VforVIBE »
You just make sure you take good care of that new paint
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
JesseWHHS
Post by JesseWHHS »
Hey V. well they are gonna redo it when I get it fixed. The paint sucks right now. It dried out in spots and I dunno. I was mad though. They are gonna repaint it for free though.
Whelan
Re: (JesseWHHS)
Post by Whelan »
Jesse I know its in the shop but I have to say it being the meticulous ******* I am.DIRTY WHEELS, AAAAAAAAAHHHHHHHH!!!!!!!Maybe you should sell the Vibe and get a BMW or Audi.
2012 GLI Autobahn 6MT
JesseWHHS
Post by JesseWHHS »
I wish. haha. I make around 200 - 250 a week. I cant afford anything else really. The wheels, I must explain. My buddy gave me some tire and wheel cleaner/shine stuff. Man the first 3 or 4 days, looked wet and sexy. But after that, the brake dust clinged on it. lol. I bought ceramic brakes to go all around so it shouldnt be that bad again, plus i dont use that cleaner BS on teh wheels anymore. I have already installed the front brakes, but have yet had my car back long enough to do the back ones.
JesseWHHS
Post by JesseWHHS »
so I call the guy today. He says he thinks it is a rod. Some book or sumthin he has tells him its a 19 hour job. thats like $1200......but he thinks he doesnt need to pull the engine, he thinks he can go through the oil pan or sumthin.Can anyone confirm this? I hope he calls me monday with good news. Im not gonna pay more than $1000 to get this fixed. haha. I told him $500.
Ninja_Logan
Re: (JesseWHHS)
damn, i dunno what to tell ya man. that sucks tho. mine was fine after i changed the oil in it
JesseWHHS
Post by JesseWHHS »
i flushed the oil out, cost me like $50 for that and the oil. it didnt fix anything.so now i wait until monday for him to give me a bottom line price on how much this is gonna cost to fix. if its TOO bad, ill just buy a motor out of a wrecked vibe i think. prob be cheaper.
