Quote, originally posted by kevera »They won't work with the GT.CAR GO BOMB.Oh,and it's "pulleys". The AEM Pulley kit will work fine on the GT. It is only an alternator pulley and belt. It will free up only 3-5hp. It is larger diameter than the OEM alt pulley so it will turn the alternator at a slower speed. You may experience dimming of headlights at idle, but that should be about it. It is not recommended if you have a large wattage aftermarket sound system, but other than that you shoould be fine.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by BlueCrush »The AEM Pulley kit will work fine on the GT. It is only an alternator pulley and belt. It will free up only 3-5hp. It is larger diameter than the OEM alt pulley so it will turn the alternator at a slower speed. You may experience dimming of headlights at idle, but that should be about it. It is not recommended if you have a large wattage aftermarket sound system, but other than that you shoould be fine.Your right.Haven't had much sleep.No crank pulleys on a GT or XRS.Quote, originally posted by keithvibe »Car go "boom" LOL ahahaha,LMAOBTW,it's spelled "boom"I should take some of my advice.
sorry I couldn't contain myself... I had to do it... LOL it's ok.. your mind is else were... I will be the first to admit I am one of the worst spellers ever... but your finger slip just made my day LOL
