How would you recomend improving the handeling in a base '03 vibe. I'm not looking to spend $$$ but if there are ways to decrease the amount oversteer that would be great. Thanks,~Snake
For free? Find a place that does free alignment checks to make sure your alignment is good. Then, you could play around with tire pressures a bit. Others may have more ideas than that.Rear sway bar helps quite a bit and it isn't too expensive. After that though, you would have to look into lowering springs.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
You gotta pay to play... but a rear SW is only about 100-150$ that'll make the biggest improvement... well besides improving the driver.... Most American cars are designed to under steer, as a "safety" cause not so many people can control the over steer (that's changing with the advent of drifting, but not in the general populous) A front driver can be coaxed into over steer by using "lift throttle over steer" or at the apex of a turn, lift off the gas and transfer the weight forward.... BUT, this is something that MUST be practiced or you'll stuff it into a tree... you didn't even hear it from me.... lol... a sway bar will "help" but it's just one part of a "system" the suspension "system" so changing just one part isn't going to be as good as changing the system... Tires and tire pressure helps a lot to (as mentioned on the pressure)
Quote, originally posted by Mavrik »Rear sway bar, Front strut bar, springs and 17" wheels with low profile tires are your best bet for improving the handling. +1 I totally agree, I have a strut tower bar and hotchkis lowering springs and it helped a TON. Looking at getting a sway bar set soon.a good deal is a DC sports STB for about 100 on ebay or from another member on genvibe or matrixowners.springs i got brand spanking new on ebay for 80, half the price retail!sway bar set you have to search for used from members or a new set off ebay or like neverenough.
