...can I safely perform without voiding the lease and with the AWD option (I know there is less I can do b/c of this).I am thinking we will buy the car out since we will be way under the km limit, but I'm not 100% sure.
K&N drop-in filterGrafxwerksStrut Tower BarGround Wire KitVoltage StabilizerEtc...Basically anything you can add easily remove that doesn't change or alter the original configuration of the car under the terms of your lease.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Essentially you can do anything to the car that you can reverse. Which is almost anything. Adding wheels and such and dropping it are also not out of the question, the kicker is you have to keep all the stock components and and put them back on when your done. But then what to do with the parts. Sell at a discount I guess.
