How do you remove the radio.
bmcm
Post by bmcm »
I just bought a peripheral interface for my vibe and I don't know how to remove the radio. I am a visiual learner so if anyone has pics that would really help. Also has anyone hooked this to their system, and do you think an amature like myself can do it.My vibe is an 04 with the m&t package.
kevera
Re: How do you remove the radio. (bmcm)
Post by kevera »
vibecrxsi240sxse
Post by vibecrxsi240sxse »
Just to let you know, I bought one of those interfaces from Best Buy that listed my '04 Vibe on the box. Bought it Friday May 19... last week.I too have the moon & tunes package, yet the installer couldn't get the interface to work. I do have a 100w amplified bazooka sub hooked to mine although that shouldn't matter in this case.Now, before we start bashing BB installers, he did tell me that this was the first time in 3 years of installing that he couldn't finish the installation. He did get the charging function to work but no sound ever came through the stereo from my ipod. I assume that is your goal with the interface.Please let me know if your Vibe worked with this interface 'cause I'll take it to a better installation place, maybe like tweeter or something.
kevera
Re: How do you remove the radio. (vibecrxsi240sxse)
Post by kevera »
Look through the"audio" section here.It gives you direction on how to hook it up.
northvibe
Post by northvibe »
i just got the thing from a friend, wheres the best 12v constant power to use?
AKLGT
Post by AKLGT »
i know there is a good how to somewhere on this forum. i do know you have to pull the middle knob off so you can get to one of the screws.
AKLGT1998 Subaru 2.5RS
northvibe
Post by northvibe »
i have the radio out..didnt need to pull anything but the bezel and radio
DHelm72
Re: (northvibe)
Post by DHelm72 »
Yep, The radio comes out in 5 minutes. Pull the bezel, unplug the accessory plugs and the HVAC vent control cable. Remove 4 screws holding in radio and you're done.
northvibe
Post by northvibe »
what..no thats not my question where do i put the peripheral 12v power....
kevera
Re: (northvibe)
Post by kevera »
Quote, originally posted by northvibe »what..no thats not my question where do i put the peripheral 12v power....Battery power is the Blue/White (sometimes Blue/Yellow) wire on one corner of the larger 24-pin connector.
northvibe
Post by northvibe »
is there a pinout of that 24pin plug? this is a generic ipod thing so i dont have the "vibe" pinout
kevera
Re: (northvibe)
Post by kevera »
Quote, originally posted by northvibe »is there a pinout of that 24pin plug? this is a generic ipod thing so i dont have the "vibe" pinoutWhat do you mean?I thought you wanted to hook up the 12volts.
northvibe
Post by northvibe »
yeah..well when you say blue/white then sometimes blue/yellow that makes me think you arent 100% positive hahah. sooo i wanted a pinout so i know exactly what the 12v is.
kevera
Re: (northvibe)
Post by kevera »
There is only one wire with the blue/white or blue/yellow combo and it's on the end of the connector,it's hard to miss.If your not confident in that,then pull out a voltmeter and test it.But that's where I hooked mine up.
audiovibe
Post by audiovibe »
Someone ask for a radio pinout??? Battery BLUE/WHITE (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Dimmer WHITE/BLACK (-) RADIO HARNESS Power Antenna BLACK (+) RADIO HARNESS Amp Turn On BLACK (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Amp Location UNDER FRONT PASSENGER SEAT Aron
Vibe is gone and will be missed as I've gone country style
Silverado Man
Re:
Post by Silverado Man »
I'm looking to order the iPod2car adapter what part #'s do I need? In the applications list on there site it only shows 2004-2005. I just want to get the right part #'s before I order.
kevera
Re: Re: (Silverado Man)
Post by kevera »
Did you read this thread,3rd post down.It's shows compatible years.http://forums.genvibe.com/zerothread?id=21818
northvibe
Re: (audiovibe)
Post by northvibe »
Quote, originally posted by audiovibe »Someone ask for a radio pinout??? Battery BLUE/WHITE (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Dimmer WHITE/BLACK (-) RADIO HARNESS Power Antenna BLACK (+) RADIO HARNESS Amp Turn On BLACK (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Amp Location UNDER FRONT PASSENGER SEAT AronThanks Aron! Kev. and you are right, looks like i need to tap a roo on that blue/white. I can finally put it together today!
kevera
Re: (northvibe)
Post by kevera »
Wuhoo!
Silverado Man
Re: Re: (kevera)
Ok great post. Looks like it will work. So I basically will need the PXDP adapter with the PXHGM3 harness? Thanks.
ragingfish
Re: (northvibe)
Post by ragingfish »
Quote, originally posted by northvibe »yeah..well when you say blue/white then sometimes blue/yellow that makes me think you arent 100% positive hahah. sooo i wanted a pinout so i know exactly what the 12v is.From http://forums.genvibe.com/zero...61195Quote, originally posted by ragingfish »When I pull out my radio, there's a 24 pin connector back there...In addition, here's the pin diagram from the service manual:
2009 PONTIAC G8
northvibe
Post by northvibe »
they are using some odd colors...brown for ground and blue/white for power...whateva ill go try it in a min...
northvibe
Post by northvibe »
kevera
Re: (northvibe)
Post by kevera »
Stop procrastinating and get your (removed) outside and do it.
northvibe
Re: (kevera)
Post by northvibe »
Quote, originally posted by kevera »Stop procrastinating and get your (removed) outside and do it.dude...if i got all my projects done...what would i have to look forward to and tell my fake gf im to busy to watch chick flick tv's with her.
kevera
Re: (northvibe)
Post by kevera »
Ummm.....fake girlfriends,too much info.
northvibe
Post by northvibe »
uhhhh didnt work yet.. i check dip switches
northvibe
Post by northvibe »
uhhh crappy, i dont have a splice thingy..........uuuuuuuuuuuuuuhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
northvibe
Post by northvibe »
ok got it working, with temporary engineering skills...until turkey weekend i can properly splice that awesome little wire.
kunkstyle
Re: (northvibe)
Post by kunkstyle »
Quote, originally posted by northvibe »ok got it working, with temporary engineering skills...Bubblegum, tin foil, and a paper clip?
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
northvibe
Re: (kunkstyle)
Post by northvibe »
Quote, originally posted by kunkstyle »Bubblegum, tin foil, and a paper clip?and a pencil
ragingfish
Re: (northvibe)
Quote, originally posted by northvibe »and a pencil hopefully a dixon ticonderoga #2.my personal testing has shown that no other pencil lasts in a jury-rigging scenario.
2009 PONTIAC G8
northvibe
Re: (ragingfish)
Post by northvibe »
Quote, originally posted by ragingfish »hopefully a dixon ticonderoga #2.my personal testing has shown that no other pencil lasts in a jury-rigging scenario. hahha nice, well it works well, but charges my ipod/iphone even if the car is off...so i just I just have to unplug the ipod/iphone every time i turn the car off :/
