My Dad asked me to transfer 40 jpegs from his digital camera to a cd-r. I can do that using OEM Roxio software on my dell computer. However dad wants these pictures to appear on the CD in a specific order. Is it obvious how to tranfer the jpegs to a CD using Roxio so they appear in a certain order after the burning?
The computer at the end of the line (the one loading the CD) will define the order things appear in. However, by default that will be alphabetical or numerical by file name assuming nobody has changed that default.If you rename the files so that they are in order alphabetically or numerically you should be good to go.
Quote, originally posted by millster »If you rename the files so that they are in order alphabetically or numerically you should be good to go.Thanks for the advice. It worked as advertised
Quote, originally posted by keithvibe »(removed)... what is that cat doing on the hood of your nice VIBE... I would go insaneThe cat is mine. Family can take some liberty with family possessions . ANyways I was never uptight about 'scritches and scratches' on the Vibe.
