Hvac door actuator
lars_seg45
Hvac door actuator
Post by lars_seg45 »
How do you replace the hvac door actuator motor without taking the dash out??I have tryed with a 1/4 flex shaft on the top bolt with no luck so far.
engineertwin2
Post by engineertwin2 »
I tried to do it without removing the dash, but it was well worth the hassle of pulling the dash - MUCH EASIER...that's all I can really say...way too difficult to do without removing the dash.By the way, welcome to genvibe!
DopeVibeGT
Re: (engineertwin2)
Post by DopeVibeGT »
Curious, why does yours need replaced? Ever since I turned the AC on this year a week ago, I get a 'clicking' noise from the dash, like a vent keeps opening and closing. It goes away if I turn on the cabin recycling button thingie.
Pictures of my ride!!'03 Vibe GTMy AED GA!Work in progress
engineertwin2
Bingo! That was what prompted me to replace it DopeVibeGT...the limit switches burn out on the actuator and it sits there and continues to try and open and close the damper. The part is between $35 and $50 (different Pontiac dealerships) and believe it or not it wasn't cheaper at Toyota in my neck of the woods.I put in some photos on here somewhere...
tinder
Re: (engineertwin2)
Post by tinder »
i'm having the same problem, and I've had the part sitting in my glove compartment for the past month trying to figure out how change out the part.Do you have a link to how to remove the dash?Thanks.
kevera
Re: (tinder)
Post by kevera »
Ask and you shall receive,thanks to Raging.http://forums.genvibe.com/zero...29847
