Battery Leak
tcam
Battery Leak
Post by tcam »
So my battery is only a few months old now, and for some reason it's starting to leak fluid pretty badly. I have a set of hyper ground wires and an ignition amlipier, put I doubt those would be contributing to this leak. And I really have no idea how to fix this. Anyone know what typically causes a battery to start leaking?
kevera
Re: Battery Leak (tcam)
Post by kevera »
Well not good news.First,battery's leak if they are overcharged,causing it to boil.So check your charging system.Also check to see if there is a crack in it,that can cause it to leak too.It could be from the add on's you have,or mabe something not hooked up right,but take care of it right away,it can cause a few problems,it can cause peeling paint, damage wiring.
Mavrik
Re: Battery Leak (kevera)
Post by Mavrik »
where is it leaking? perhaps your battery tie down was tightened to much and crushed the lid?
tcam
Re: Battery Leak (Mavrik)
Post by tcam »
Quote, originally posted by Mavrik »where is it leaking? perhaps your battery tie down was tightened to much and crushed the lid?it's leaking out of the two pad things on top.Quote, originally posted by kevera »Well not good news.First,battery's leak if they are overcharged,causing it to boil.So check your charging system.Also check to see if there is a crack in it,that can cause it to leak too.It could be from the add on's you have,or mabe something not hooked up right,but take care of it right away,it can cause a few problems,it can cause peeling paint, damage wiring.so should I take it somewhere and just have the alternator looked at?
kevera
Post by kevera »
Mavrik brought up a good point,is the battery hold down nut too tight.Do you have a voltmeter.It's an easy check.Test the battery with the car off,you should have between 12-13 volts.Then with the car running,you should have a high 13-14volt range.If you don't have a voltmeter,then get it checked out to make sure.
tcam
Post by tcam »
Quote, originally posted by kevera »Mavrik brought up a good point,is the battery hold down nut too tight.Do you have a voltmeter.It's an easy check.Test the battery with the car off,you should have between 12-13 volts.Then with the car running,you should have a high 13-14volt range.If you don't have a voltmeter,then get it checked out to make sure.no the battery is slightly loose if anything. But I will take it to a shop to have it checked out. thanks
