Over the last month or so, the car has failed to start 3 times because the battery is not holding a charge. Today I was listening to the radio for about 40min while my wife was spending my money in a store. When I went to start the car, all I got was the click, click, click. luckily, we carry a set of jumper cables so I was up and running in a few minutes.I think I should be able to listen to the completely stock radio for 40mins and not kill the battery. I have done it for over 4 hours in the z/28 while I washed/waxed/cleaned it with no problems.If I take the car into Pontiac, will they replace it free of charge under the 3year/36k mile warranty???Thanks!
Joe2005 Vibe GT2000 Silverado 4x41993 Camaro Z/28Riding a '05 GSXR-1000. ~ Full (removed). Akropovic exhaust, power commander, custom map = 166 horse My wife rides a crazy fast Ninja 250
Thanks djb383. My guess is that the dealer is going to see that I have 33,800 miles on the car and say there is nothing wrong with it. Yeah, the car starts and the battery tests good but if it sits for 2 weeks or leave the radio on for half hour or leave the doors open while detailing the inside ~ the battery is crap.
yes the battery is covered but in most causes there needs to be a cause of failure. Example being I got mine replaced under GM warranty but the battery was leaking acid. Other times it could require a test. If it passes the test but doesn't seem to hold a charge if it sits a while, make sure they test it after it sits a while. Otherwise if you drive in and they test it right away, it could test fine. Have a starter/charging and draw test performed.
yes the battery is covered under warrenty. A week after I bought my Vibe the battery went bad... took it back to the dealer and they replaced it no charge. They said it had a bad cell. I haven't had a problem with the battery since.
I just got back from the Pontiac dealer. The battery was bad. They replaced it with another junky AC Delco........I'll probably be replacing it in 2 years. Its no wonder GM is no longer #1.
If it was free then all is good (even if it is for only another 2 yrs)
ex Vibe: 2005 Abyss 2 tone base, auto, power package (33.24 mpg combined)2008 Kia Rondo EX V6 7 passenger Volcanic Red w/ tan cloth interior (26.7 mpg combined) Finally got 30 mpg combined on the Rondo V-6 (10.24.09) Smith Driving
