DC Sports Header
Celtic_Curse
DC Sports Header
Post by Celtic_Curse »
Hey everyone,Just got my DC Sports Header installed and noticed a couple of things which made me have questions.1. did anyone have a rattle after the install frm the header vibrating the bottom heat shield around the joint?2. What does it sound like on your car? does it sound like it may have a leak?3. Is there a break in period as to when it needs tightening again?Thanks for your help.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
tcam
Re: DC Sports Header (Celtic_Curse)
Post by tcam »
I don't know specifically about the DC Header, but I have a couple ideas that might help. Did you replace both the donut gasket, and the head-to-manifold gasket? And is the header ceramic coated? if so, then you don't even really need those heat shield if they're giving you rattling problems.
northvibe
Post by northvibe »
yeah forsure check if you put your original donut gasket on the DC and we..yea what tcam said about ceramic coating.
Raven
Post by Raven »
I've had mine for 6-7 months.1. No rattles.2.Mine leaked on the first 2 tries and then I torqued down the header to exhaust connection with the system red hot (donut).3.Any header should be re-torqued after 200 miles and then check it every few months after that.
tcam
Re: DC Sports Header (Sunny)
Post by tcam »
Quote, originally posted by Sunny »I've had mine for 6-7 months.1. No rattles.2.Mine leaked on the first 2 tries and then I torqued down the header to exhaust connection with the system red hot (donut).3.Any header should be re-torqued after 200 miles and then check it every few months after that.how did u detect ur leak? u just put ur ear up to the header or something?
northvibe
Post by northvibe »
from what i hear when it leaks it makes a loud hissing noise...like a rattle snake is all up in your engine trying to steal powa
Raven
Re: DC Sports Header (tcam)
Post by Raven »
Quote, originally posted by tcam »how did u detect ur leak? u just put ur ear up to the header or something?Mine was quiet until you pressed hard on the gas pedal and all of a sudden it sounded like a truck with no exhaust. You would not want your ear anywhere near it. A less severe hissing or ticking sound usually indicates a leak in the manifold gasket and is usually present even when idling.
Whelan
Post by Whelan »
DC headers are loud. Try retorquing and driving for a bit then rechecking. And the heat shield can be removed.
2012 GLI Autobahn 6MT
Celtic_Curse
Thanks everyone,It is ceramic coated. I moved up the heat shield around the donut and no effect so I took it in. Turns out when I first installed my Magnaflow exhaust I had pushed it too far forward and one of the bends was touching the shield. That got fixed and now no more rattle. I notice a hissing however I can not detect any leaks and it could be I just need to get used to the sound which is a lot deeper. I had the exhaust guy retorque everything down and now no issues.Thanks for everyone's help and suggestions, I really appreciated it!!! The system appears to be purring quite nice now can't wait to open her up on the track soon.
