Pop Ups
Vibegrrrl
Pop Ups
Post by Vibegrrrl »
I have not been a member here for very long, however shortly after becoming a member here I started to receive "pop ups". The "pop ups" come up on a grey window with plain text...usually asking me to watch someone strip or get off. It is always pornographic in nature. I usually just ignore it, cause whatever it doesn't usually bother me I am not a prude, but I don't need the computer screen to get stimulated. Anyway...I do spend a considerable amount of time on the net searching journal material as I am working on my Master's Degree but I only receive the "pop ups" while I am on the Vibe Forum. My question is...does anyone else get the "pop ups" and could it be from a member here?
Base AbyssMonotone5 speed manualmolded splash guardsBadge overlays by Grafxwerks16" Aluminum...impatiently waiting for turbo...
rasermon
Re: Pop Ups (Vibegrrrl)
Post by rasermon »
Good afternoon.Download this software to remove spy-ware from your pc, also delete your cookies. http://download.com.com/3000-2144-10186 ... ag=lst-0-3 1.45MB Ad-aware
Satellite 03 GT Retirement ----> Moderator for Genvibe.com 2002 - 2007 A fact of life: After Monday and Tuesday even the calendar says (removed)
Vibegrrrl
Re: Pop Ups (rasermon)
Post by Vibegrrrl »
Thanks Rasermon...much appreciated!!
rasermon
Post by rasermon »
Anytime! Ad-aware should clean it up. If you run into problems IM me.
Keely
Post by Keely »
You may also want to look into browser alternatives that block pop-ups. I've been using a freeware IE add-on called Avant Browser http://www.avantbrowser.com/. It has a pop-up blocker that you can toggle on and off with the click of a button, which is handy when you want to have an IM session with a fellow GenViber (the IM box is interpreted as a pop-up window and therefore blocked from appearing at all). In addition, it has a great MDI functions (many pages appearing as tabs in a single Avant window rather than having many windows open) and lots of other cool features. Although it is a bit of a resource hog, you can't beat the price. Hope that helps!
keely dunn
Geo
Re: Pop Ups (Keely)
Post by Geo »
Mozilla is also a good browser out there that can automatically block all incoming popups. http://www.mozilla.orgI personally use Safari, before that Mozilla and Chimera (now known as Camino), yes I am also a Mac user (w00t!), and using browser-integrated popup blocking, I have not seen an unrequested popup in well over a year - if not longer. Browsing is so nice now :D
BADGER PRIDE
KSNeptune
Post by KSNeptune »
If you are using window's XP ir NT or 2000, you may be a victim of the exploited "messaging" feature. It was intended to let sysop managers send employees hooked into an office network messages like "The network server will be shut down in 5 minutes. Please save all you work now."If you are NOT in an office using the offices computer, then you can disable this "feature". Tell me what operating system you are running and if it's XP I'll tell you how to turn it off.KSNeptune
coratz
Re: Pop Ups (KSNeptune)
Post by coratz »
what if you use kazza like me? if i stuck with that save now pop up crap?
cohocarl
Post by cohocarl »
Doesn't sound right. I have never had a "pop-up" on this forum and I'm running Win xp, 2000 and ME, with I.E. I'd try Rasermon's recommendation on deleting cookies if you haven't, and run AdAware. Keep us informed if it still does it or not.
esjones
Re: Pop Ups (cohocarl)
Post by esjones »
quote:Doesn't sound right. I have never had a "pop-up" on this forum and I'm running Win xp, 2000 and ME, with I.E.Same here (Win 2000 Pro). I have a bookmark, though, that takes me directly to the fora, bypassing the main page.
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
d_m_kolb
Post by d_m_kolb »
This is the first I have heard of this. genvibe.com doesn't use pop up of any kind for advertising. Also we wouldn't allow porn advertising of any kind on this site in the first place. We do use the instant messaging system but that's different.Does this only happen on genvibe.com or on ever website you visit?
Vibegrrrl
Post by Vibegrrrl »
Hey KSNeptune,I am using XP, thanks for the assist.Thanks to everyone for their input. Much Thanks!!
Vibegrrrl
Re: Pop Ups (Admin II)
Post by Vibegrrrl »
Only when I am on Genvibe. My partner is also on the net alot, never here, and has not had the same popups. It could be coincidence...you tell me.
rasermon
Post by rasermon »
quote:Only when I am on Genvibe.I'm also having problems with genvibe, just when viewing the forums.No pop-ups, but not all images will load. When I'm not logged in its fine. Corrupt cookies
mu_ohio
Re: Pop Ups (silverawd26)
Post by mu_ohio »
Netscape also has built in pop up protect and it seems to work very well. Currently I'm using Safari on my PowerBook, but it seems to be a lot like Netscape. I actually think they are built on the same engine. I would turn on WinXP's firewall since it will prevent spam messages from Window's Messenger, or at least in my experience.
2004 Pontiac GTOPhantom Black w/black leather
NSimkins
Global Moderator
Re: Pop Ups
Post by NSimkins »
quote:Only when I am on Genvibe.I'm also having problems with genvibe, just when viewing the forums.No pop-ups, but not all images will load. When I'm not logged in its fine. Corrupt cookies Very interesting indeed, but you are not alone. I noticed the same 'issue' on the forums as well. This was predominately worse when most of the forum images were being pulled in from zeroforum.com rather than genvibe.com's own server. This means, when zeroforum.com's server was experiencing slowness or difficulties, the forum would never completely load up the page and prevent IM's and other features from operating properly.I recently moved all forum images over to the genvibe server and personally have noticed much better performance, but not completely. For example, older posts that still reference zeroforum.com's server in their images may still experience slowness depending on their server's status. Gradually, that should work itself out of the forum threads.Another point to note as well, I ran Windows Update on my XP box (10 updates in 2 months, no surprise ) and noticed IE performance was improved.However, there are a couple patches out there that will actually worsen IE/Windows performance. Thanks to rasermon for pointing out this link:http://www.broadbandreports.com/forum/r ... latAnother note, as Admin II stated, we do not utilize pop-up advertisements on GenVibe, except for the IM pop-ups. In many cases, installed programs like Kazaa and other ad-ware based programs will cause random pop-ups when launching IE. Use the advice given above from other members on how to alleviate this problem. Now, things may change on the site without Admin II or myself knowing.... it happens, but we try to stay on top of things that will affect site performance.As always, please feel free to IM or e-mail me if you experience ANY forum problems.
esjones
Post by esjones »
quote:What does corrupt cookies mean? And do not try to pull a fast one by telling me it has something to do with a Kebler Elf or The Cookie Monster... LOL. Serious, I do not even know what cookies are Cookies are small files that a web site can store on your computer, and then ask for later, and your browser will send it back. They are used to identify and track you. It is how GenVibe recognizes you when you come back, for example.
Stang2Vibe
Re: Pop Ups (NSimkins)
Post by Stang2Vibe »
quote:the forum would never completely load up the page and prevent IM's and other features from operating properly.I was experiencing this very frequently within the past 2 weeks. I was worried that it was my internet connection.I also use Kazaa and hate those stupid "Save Now" popups that plague my surfing experiences. Maybe I will have to try one of these popup blocking programs.
rasermon
Re: Pop Ups (Stang2Vibe)
Post by rasermon »
quote:I was experiencing this very frequently within the past 2 weeks. I was worried that it was my internet connection.I just did a clean install XP home with the same problem viewing genvibe forums. I'm sure this is a problem with the server zeroforum.
KSNeptune
Post by KSNeptune »
VibegrrlGo to STARTRUNenter "services.msc", then click OKFind MESSENGER in the list on the right panelRight click on it, select PROPERTIES.On the GENERAL tab, about half way down, change Startup Type to "DISABLED"That will disable the messenger "feature", and if it is where your pop-ups were coming from they should stop next time you've rebooted and then gotten on the web.Good luckKSNeptune
millster
Re: Pop Ups (joatmon)
Post by millster »
You might want to check in your profile and make sure your e-mail address is not being displayed on the site (in fact, a quick peek at your profile shows it is being displayed). You can turn this off in your My Profile section. There are crawlers out there searching for visible e-mail addresses on webpages and spamming them if found. If you do want people to be able to e-mail you, just sign up for a free web-based e-mail address. When I signed up, I just used an already spam laden Hotmail account.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
Vibegrrrl
Post by Vibegrrrl »
Thanks KS!!
Big_Red
Post by Big_Red »
Personally, I have never had this problem while on this site, but I do feel the pain when I go elsewhere.
2003 Pontiac VibeSalsaPower PackageSports PackageK&N Air Filter
KSNeptune
Post by KSNeptune »
quote:Thanks KS!! You are quite welcome. Let me know if my advice worked.KSNeptune
