You would have to change out a couple chrystals inside your ECU. It will completely remove your rpm limiter. Not recommended!! People who have done it have blown their engines due to revving too high.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Also, you'll be running the risk of floating a valve at those high rpms. If your getting 'bigger' cams I can see raising the rpms a little. But on a stock 'ish' engine I agree that it wont do you any good. The easiest way to raise the rpm limiter is to go with a stand alone ecu.
