GPS Antenna On/Off Switch
ProtonXX
Post by ProtonXX »
Anyone ever tried this before or know if this is possible? I need a switch because my GPS system turns the DVD/Input video off when the car is moving. The only way to trick it is to unplug the GPS antenna.
Whelan
Re: GPS Antenna On/Off Switch (ProtonXX)
Post by Whelan »
check ebay, Pioneer used to make a bypass for cars with dvd/nav combos
2012 GLI Autobahn 6MT
ProtonXX
Re: GPS Antenna On/Off Switch (Whelan)
Post by ProtonXX »
Found a better solution, moved the mute wire to a the pin above it & grounded it. Everything works now :D
