Hi, I'm new here, only had the Vibe for 2 days now and love it. I'm looking to setup the Vibe like I have my previous cars/trucks and I need to know where I can tap some power lines in the dash and console.For the dash, I need about 3 amps, ignation controled if possible for a Whelen Dash strobe that I use for my Fire Department. I'm also thinking of placing the switch for th light in one of the empty slots to the left of the stering wheel next to the change holder and rear hatch release. Any good stops to tap for power and how would I get to the switch location.For the console, I was thinking of taping the input lines to the 12 volt outlet in the base of the console. Any special tricks to getting the console un-bolted from the floor? I'm going to install my scanner inside the the botton console with 2 sided tape to keep it out of view but allow easy access to the controls. Since the scanner takes less then 1 amp in power, I shold be ok taping the outlet.BTW, anyone got a good spot for an external antenna on the Vibe. I'm thinking some sort of lip mount off the front hood area since I don't want to drill any holes and the hatch doesn't leave any mounting options.ThanksChris
------------------------------------------------------------------------------2003 Pontiac VIBE AWD Mono-Tone Neptune - GONE "Drive It Like You Stole It!"
