Aluminum Wheels
mkl116
Aluminum Wheels
Post by mkl116 »
I received my brochure from Pontiac and all the wheel types aare similar "sawblade" style. The covers, 16 inch and 17 inch all have a similarlook and I think most people agree saw bladess were out of style close to 10 years back. Has anyone seen if other wheel options exist? The 5 spoke wheels in the Motor Trend article looked great!
MA-VIBE-FAN
Re: Aluminum Wheels (mkl116)
Post by MA-VIBE-FAN »
The most commonly mentioned tire/wheel place on the net in http://www.tirerack.com
yank dini
Post by yank dini »
You have a lot of options when it comes to wheels for the VIBE. Pretty much this is the only "aftermarket part" in which you have a lot of choices. Just look for wheels with a 5 bolt pattern. Example: I had 18 inch wheels on a 2000 Dodge Stratus SE that I wrecked in MAY those same wheels fit on my VIBE. I put them on the day after I bought it Heres a site that has a list of wheels for the 2003 PONTIAC VIBE: http://www.tires.com Just do me a favor, Please don't get chrome wheels (too expensive and they look cheap on that car) or ENKEI CDR-9's (those are my wheels) Thank you.
NovaResource
Post by NovaResource »
mkl116, Do you mean this Car and Driver article: http://www.caranddriver.com/xp/Caranddr ... uevibe.xml And these wheels:If so, I purchased a set of 17x7" Voxx MGR wheels from http://www.tires.com that look exactly the same:
[Modified by NovaResource, 3:37 PM 7/8/2002]
NovaResource
Re: Aluminum Wheels (fritzburg)
Yes, I like the silver wheels better than chrome.
NSimkins
Global Moderator
Re: Aluminum Wheels (NovaResource)
Post by NSimkins »
Is the pic of that Vibe with those 17's at stock height with just the wheels added, or is it dropped? Looks good with them!
NovaResource
Re: Aluminum Wheels (NSimkins)
I'm not sure. It looks to be at stock height but the wheels appear to be 18" (just judging by the space inbetween the inside of the wheel and the rotor).
NSimkins
Global Moderator
Post by NSimkins »
Thanks Scott. You said you purchased those but in the 17" size? Do you have them on your Vibe yet? When you do, take some pics.. I would be interested to see them on a Vibe!
NovaResource
Yes, 17x7". They should be here Friday or Saturday. Don't worry, I'll be taking pics as soon as they are installed and posting them here.As much as I dislike standard wheels and wheel covers on most cars, I have to give credit to Pontiac designers for making a very nice standard wheel cover for the Vibe. They look very much like the 16" aluminum wheel and from 50-ft most people can't tell they aren't aluminum wheels.When I picked up the car and saw them for the first time, I almost regretted ordering the aftermarket wheels....................NOT!
NSimkins
Global Moderator
Post by NSimkins »
quote:Yes, 17x7". They should be here Friday or Saturday. Don't worry, I'll be taking pics as soon as they are installed and posting them here.I can't wait to see them!quote:As much as I dislike standard wheels and wheel covers on most cars, I have to give credit to Pontiac designers for making a very nice standard wheel cover for the Vibe. They look very much like the 16" aluminum wheel and from 50-ft most people can't tell they aren't aluminum wheels.I will agree with you about the wheel covers! At least they didn't put covers like the new Sunfire's... those things are horrible! More and likely I will get the 16" aluminum wheels with my Vibe and buy aftermarket and swap wheels from winter to summer driving.
NovaResource
quote:I will agree with you about the wheel covers! At least they didn't put covers like the new Sunfire's... those things are horrible!You are so right. Those Sunfire wheel covers are bad.quote:More and likely I will get the 16" aluminum wheels with my Vibe and buy aftermarket and swap wheels from winter to summer driving.That's what I will probably do. I debated about saving a little money by just ordering 16" aftermarket wheels and using the stock tires but then I decided to just buy 17" wheels and good performance tires and save the stock 16" tires and steel wheels for winter use.
NSimkins
Global Moderator
Re: Aluminum Wheels (Waiting4Vibe)
Post by NSimkins »
We get an unpredictable amount of snow each year. Sometimes we get a ton and sometimes it is light. I personally find that All Season tires provide a sufficient amount of traction during that part of the year.The All Season's on my Cavalier are pretty decent.. so I assume the All Season's on the Vibe are comparable in this case.It is just that if I get aftermarket wheels, I won't use them in the winter.
NovaResource
Ditto. Here in Philadelphia we could get alot of snow or none. However, when we do get snow, it gets cleared fairly quickly. My old '93 Sunbird had 195/65-15 BFG Touring T/A tires and I never had a problem in the snow. My main reason for using the original tires and wheels is the ton of road salt used here. I don't want it tearing up the aluminum wheels.
NSimkins
Global Moderator
Post by NSimkins »
quote:My main reason for using the original tires and wheels is the ton of road salt used here. I don't want it tearing up the aluminum wheels.That's my exact reason too! I'm sure it's the same here as it is there.. not too much of a distance between our two locations. The amount of salt they drop during snowfall is unbelieveable.. that stuff stays on the road forever.
NovaResource
It must be my lucky day! My wife just called to say my wheels and tires (which were supposed to be delivered on Friday) just arrived today! Woo-hoo! Discount Tires under-promises and over-delivers. What a plesant surprise.Wait, I'm not done. Right after I hung up with her, my dealer called to say my 6-disc in-dash CD player and key fobs also arrived today. I'll pick up the fobs on the way home have have the CD installed either tomorrow or Thursday!I'm going out an buying a lottery ticket!
NovaResource
Ok, you asked for pictures of the wheels installed, here they are:
[Modified by NovaResource, 11:39 AM 8/22/2002]
NSimkins
Global Moderator
Post by NSimkins »
Looks awesome Scott! Thanks for posting the pics so fast.What tires did you get for the wheels?
NovaResource
The same size as what comes on the optional 17" wheels: 215/50-17. Mine are a set of Falken ZE-502.
NovaResource
A very close match. The pre-prod car looks like 18" wheels.
NSimkins
Global Moderator
Post by NSimkins »
Yes, looks very close. Definately like the straight spoke design better than the stock sawblade design.Did you get the 17X7 5-100 38S size wheels?Also, did you buy the tires from tires.com and have them balanced/etc. before shipping? I am curious on how this works.
[Modified by NSimkins, 10:47 PM 7/9/2002]
NovaResource
quote:Did you get the 17X7 5-100 38S size wheels?Exactly.quote:Also, did you buy the tires from tires.com and have them balanced/etc. before shipping? I am curious on how this works.Yes. I also paid an extra $40 ($10 per wheel) for locking lugnuts and chrome valve stems. The wheels were mounted, balanced and delivered directly to my home at no cost. It was a simple unbolt and replace.The wheels come shipped with a sheet of foam and cardboard on either side of the rim to protect it during shipping. The cardboard was held in place by 4 nylon straps per wheel and a bunch of packing tape. Only the tread was exposed. Plus they were delivered 3 days early. I ordered then Friday (7/5) and they were here Tuesday (7/9). Very impressive.
[Modified by NovaResource, 8:02 AM 7/10/2002]
NovaResource
$1,124. No bad when you consider the stock 17" wheels are a $1,300 option ($800 for the wheels and $500 for the required ABS).
NSimkins
Global Moderator
Post by NSimkins »
Definately a good price.. and considering the service you have had with tires.com, I'm sure it makes it all worth it.You get better looking wheels than the stock 17's and save money in the process.
der125
Post by der125 »
I agree, nice wheels?I bought the GT with the sunroof and I'm now looking for 17" wheels. Does anyone know how much the OEM 17" wheel weighs? If anyone has this wheel, can you stand on a scale with the wheel? Please!! I don't want to buy 17" wheels that weigh more than the OEM 17".--Desperate for 17in
Abyss Monotone GTMoon & TunesSPO-rubber mats, seat covers, cargo net, cargo carpet, rr bumper coverFlannel steering wheel cover for the cold daysGarmin Street Pilot GPSMotegi 17" rimsPaint protective film-hood, handles, rear mid gateAutoventshade bug deflectorHitch - for the '94 YZ250Tint rr 5 windows-der
cohocarl
Post by cohocarl »
quote:Ok, you asked for pictures of the wheels installed, here they are:I'm also looking for a replacement wheel to replace the steel 16's that will come on mine (if I ever get it), and your Vibe looks great, but what really caught my eye was the Nova SS behind it.... What's below the cowl induction hood?Later,Carl
NovaResource
Re: Aluminum Wheels (cohocarl)
You mean this one:My signature lists what's under the hood and how quick it is. Here's all the rolling stock:
[Modified by NovaResource, 11:40 AM 8/22/2002]
cohocarl
Post by cohocarl »
Looks Cool!!. My project car is an 85 C-4. Needs paint bad. Trying to get the mechanicals done first though. Haven't taken it to a strip since I changed motors, but it's a little better than stock. (flat top pistons, 882 heads, C.C. 268H cam, siamesed intake base, true duals w/Hooker aerochambers)See Ya,Carl
[Modified by cohocarl, 10:28 AM 7/19/2002]
Campbell
Post by Campbell »
My Silver base vibe has the stock 17" aluminum wheels - looks the same as yours.By the way, any idea what the tire coating is that the dealers put on? It seems like a heavy cosmoline or underbody tar - it made a real mess of my wheels and the sides of my brand new Vibe. I got some on my toes when I washed my car and it won't come off.
Silver Base Vibe with Nav System that I wish had an OBD-II link
Lori19
Post by Lori19 »
Scott, your Nova is beautiful!
[Modified by Lori19, 10:51 PM 7/29/2002]
Lori Abyss,monotone,moon & tunes, power pkg
NovaResource
Re: Aluminum Wheels (Lori19)
Thanks Lori. A friend of mine pointed out that I must have a "V" fetish. Vibe, Voyager and NoVa. Also, all 3 are painted SilVer. LOL!
[Modified by NovaResource, 8:56 AM 7/30/2002]
Jwnmt
Post by Jwnmt »
Hey NovaResource, About 12 years ago I had a 65 Chevy II Nova, that was bright pink. I believe that it originally had the 6 with the powerglide transmission. When we bought it had a 350 with a 4 on the floor. What a car for a 17 year old. Anyway, we had to sell when I went to college and I miss the damn thing to this day. Now I am waiting for my vibe GT which should be here next week. Thanks for the link to the nova site, I don't see very many Chevy IIs around and seeing pics of them makes me remember the good old day!! Jon
