Onstar failure
loren
Onstar failure
Post by loren »
The other day I had my first opportunity to actually use my onstar, which failed miserably. While putting my 1 year old in the car, he grabbed my keys and locked the doors. I then closed the passenger door (not realizing the doors were locked), and ended up with a child locked in the car with the keys. So I called onstar, but after several attempts they were unable to remotely unlock the car. They did send a tow truck which was able to break into the car with only a couple little scratches on the trim around the drivers side window. Luckily the boy was calm and the temperature was cool otherwise I would have had to break a window instead of waiting for road side assistance. Anyway when I got home I was furious and contacted onstar to find out what the problem was. After several attempts to remotely control the car, a technician got on the line and said my software needed to be updated, which he did remotely. After about 5 minutes of updating the onstar, he was able to instantly open the door locks.I would suggest that if you have onstar you might call to make sure you don't have the same issues. Ask them to open your locks and beep your horn to make sure it works. I can't believe the first person from onstar wasn't able to update the system and open the car when I really needed it. I have learned my lesson about handling my keys with my boy, as well as relying on onstar.Loren
Mavrik
Re: Onstar failure (loren)
Post by Mavrik »
I just never leave keys around children lol...glad your situation didn't turn out more seriously though.
03VibeGT6Spd
Post by 03VibeGT6Spd »
I have use onstar for that once, and it worked.but my wife use's onstar quite often.I think she could get lost, leaving are driveway
ragingfish
Post by ragingfish »
i've used just about every feature of onstar, never had a problem.your situation is unfortunate, but at least it was remedied.
2009 PONTIAC G8
