IAC valve location?
leecaj
IAC valve location?
Post by leecaj »
Where exactly is the IAC valve located on a 03 Vibe GT?
kevera
Re: IAC valve location? (leecaj)
Post by kevera »
I sent you an IM.
kevera
Re: IAC valve location? (kevera)
Post by kevera »
Here is a pic that might help.It's the black piece with the grey connector in it.
kevera
Post by kevera »
Read through the first link I gave you in your other post,check all hoses for cracks and also the pcv valve.Cleaning the IAC valve may help,but replacement may be your only option.
leecaj
Post by leecaj »
I will be sure to check that all out. Thanks again for all of your help!
tcam
Post by tcam »
what does it do? does it coincide with PCV Valve?
