wont stay on cuz of intake?
pontiacbanshee89
Post by pontiacbanshee89 »
hey guys...im new here..but ive been checking this place out since i got my 05 gt, but i ran into a somewhat big problem(at least for me)i bout this sri from http://cgi.ebay.com/ebaymotors...32917and i didnt come w/ instructions, so i printed out a k&n typhoon instructions and went that route, well everything seemed fine and dandy until i tried to turn on the car...then it would turn on for a second or two and then shut down,,,tried to double check(cuz the sri was a ripoff of the k&n) it wasnt exactly the same...and i then ended up putting in the original box back again..but it still doesnt want to stay on...what the heck is going on??????
ragingfish
Re: wont stay on cuz of intake? (pontiacbanshee89)
Post by ragingfish »
Any chance you damaged the MAF sensor?
2009 PONTIAC G8
kevera
Re: wont stay on cuz of intake? (ragingfish)
Post by kevera »
As Raging said,did you disconnect your battery before you removed the maf sensor.That's the black sensor located at the end of the s-tube on the stock air box.Or it could be the way the hoses are routed.What year Vibe do you have?
pontiacbanshee89
that i remember yeah i disconnected the battery oh and its an '05
pontiacbanshee89
oh yeah...and then it smells like gasoline after its on........just something else i remembered right now
Petrucci914
Re: (pontiacbanshee89)
Post by Petrucci914 »
That makes me think that you ruined the MAF sensor. It isn't functioning and the engine is then running really rich since it can't tell what type of airflow is coming in.
kevera
Re: (Petrucci914)
Post by kevera »
I thought that when it was in limp mode it ran,but not above 3k.But now thinking about it,it would run rich and that would explain the gas smell.I think your right.I hope you still have a warranty,the maf sensor is quit expensive.
Whelan
Re: (kevera)
Post by Whelan »
The car will not stay on if you have that hose connected. The hose that comes from under the engine cover from the Throttle Bodies, should be capped, as well as the pipe connection on the intake (the stalk where you connect the breather hose.Leave the stock hose on the Throttle body and cap it off. If it is not the car will start and stay running if you rev it, but dies immediately after you let off the gas.
2012 GLI Autobahn 6MT
pontiacbanshee89
which hose are you talking about...does anybody have a picplus when i put the stock box in...it did the sameand about the MAF...how are some ways i couldve screwed that up..and how much do they cost...just in case
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
if when you put it back to stock and reinstalled all the hoses to stock location... then you more then likely screwed up the MAF.They are delicate, so easy ways would be handling it rough, dropping it, hitting it, playing with the little senor part, whatever.Search out CAI or intake install and you will find the pics you need. Leave it stock, take it to a shop for proper diagnosis and try again when its running in OEM condition again.Sorry about your luck
Whelan
Re: (CAN-AWD-VIBE)
Post by Whelan »
Damaged MAF is a big deal, they are expensive parts too. When I did my intake I pulled the whole airbox off with the MAF still on, then left it there until I was ready to put it on the intake pipe at the very end. That way it did not get moves a lot.
Mavrik
Re: (Whelan)
Post by Mavrik »
Even with a bad MAF the car will start and idle fine. It just will not rev past 2500RPM. As for it not running... check your vac lines and make sure everything is connected. Also a failed MAF will set a code as well so if you have a CEL then that will tell the tale.
Whelan
Re: (Mavrik)
Post by Whelan »
MAF Codes Are COOL!!!
kevera
Re: (Whelan)
Post by kevera »
LOL
