Front wheel well cover removal?
jkm311
Post by jkm311 »
Between the front tires and the bumper, how do you remove or how is the panel secured that lines the wheel well just below the headlights? I don't seem to see any screw heads, so how is it attached? Any old threads on this? I seem to remember somebody exposing the CAI they ran down in that space, and posting the shots of it. Thanks, Vibers.
Steelies to the rescue.
Sub-Vibe-R
Re: Front wheel well cover removal? (jkm311)
Post by Sub-Vibe-R »
Do you mean the platic inner fender?If so, to remove it completly, you have the remve 2 screw who link it the the bumper, then the 5 push clips (4 in the fender, 1 under the car).After this, you have to remve the 2-3 screw on the edge of the fender, then remove the cladding. You have to pull hard since it is clipped.
jkm311
Re: Front wheel well cover removal? (Sub-Vibe-R)
Post by jkm311 »
Basically, I just need to get my arm in the space behind the headlight on the passenger side. Just screws in the way, if I am reading your post correctly...
Sub-Vibe-R
To do this, remove the 2 screw and the push clip who link the bumper and the inner fender.It is also a good idea to remove the push clip who attatch the inner fender to the fender. After this you will be able to access this area.
kevera
Post by kevera »
Sub-Vibe-R is correct.The screws and the push clips and it will come out.
jkm311
Re: Front wheel well cover removal? (kevera)
Post by jkm311 »
Thanks for the help, guys...
