PCM swap
Tubaryan12
PCM swap
Post by Tubaryan12 »
I have an '05 base and I am almost out of warranty. I only have the "hot soak" issue about once per week at most and I only have to crank it for about6-6 seconds. Even in the winter I have a combined (90/10....mostly highway) mileage of around 30 mpg with an automatic. Some of the folks that did the change are getting lower gas mileage after the change. So, should I try to get this done before I am out of wanrranty or will this still be covered after 36000 miles? Or should I leave it alone because my gas mileage is good and its not worth the risk of lowering it.
ex Vibe: 2005 Abyss 2 tone base, auto, power package (33.24 mpg combined)2008 Kia Rondo EX V6 7 passenger Volcanic Red w/ tan cloth interior (26.7 mpg combined) Finally got 30 mpg combined on the Rondo V-6 (10.24.09) Smith Driving
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
does the US have an extended emissions warranty like we do here?PCM should be covered under Emissions not 3yr/60 (or whatever the miles are)
Tubaryan12
Re: (CAN-AWD-VIBE)
I know US emission warranties are longer than 3yr / 36000 mile. If this part is considered part of that, then I'll quit stressing about it.
ragingfish
Post by ragingfish »
EDIT: Ok, I'm an idiot. If anyone saw my original post, I was WRONG! Per MyGMLink: 96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM. And what's the "hot soak" issue?
2009 PONTIAC G8
Tubaryan12
Re: (ragingfish)
Quote, originally posted by ragingfish »EDIT: And what's the "hot soak" issue?http://forums.genvibe.com/zerothread?id=20641at least that's what someone called it there.
ragingfish
Ah. That's a poorly chosen phrase IMHO. I would think hot start would be a better description. Just my $0.02 though...
2009 PONTIAC G8
Yury
Re: PCM swap (Tubaryan12)
Post by Yury »
i didn't know new PCMs reduce mileage ! darn and here i am trying to figure put why my mileage went down.does anybody know roughly how much it decreases ? i am now in 29-32 range. When the car was new I remember getting 34-35 at some point.
07 Accord SE V6.Used to own 05 Base Vibe, it was a nice car
northvibe
Post by northvibe »
Im pretty sure its the pcm's on the new DBW vibes that only have this issue. What you need to do is get the car in before your warranty expires so its on record and then if you have the issue right after the warranty expiration you can still have it covered (this goes for almost all problems) because its documented and if they didnt fix it, they have to considering hte problem happened before the warranty expired and they didnt fix it properly the first time.
jbyerley
Re: PCM swap (Yury)
Post by jbyerley »
I have noticed the same thing. Mine dropped about the same as yours.You would think they would tell you this before you switch.
