Eclipse Navigation Install - HELP!!!!!!
MichaelCArens
Post by MichaelCArens »
I realize there are a million topincs (overexaggerating) on how to install a nav, but I am so lost its not even funny. Heres the scoop:Car = 2004 Vibe w/ moon and tunesReplace Stock CD Player w/ Eclipse AVN-2454I got the unit wired last night and when I turned it on, it was severly loud...then when I muted the volume there was an audible hissing sound coming from all 6 speakers. I have read alot of people stating that in order to install the navigation I am going to have to bypass the factory amp. As far as I see it I only have 2 choices, payout $60 for the metra kit, or cut the thing apart and splice it together myself. Anyone have any other ideas???I havent seeen anything regarding the tweeters...how do I go about hooking everything up without loosing my tweeters, is it even possible.I will appreciate all help I can get with this. (anyone live local that can help me would be awesome!!!!)
Jahntassa
Post by Jahntassa »
I introduce you to the power of the sticky: http://forums.genvibe.com/zerothread?id=19021
CCD
Post by CCD »
Sounds like the OP already did all that since there was sound. Sounds like there is an input level problem. Hire a pro is what I say.
2003 base
ragingfish
Post by ragingfish »
Try a line level converter, aka scosche fai-3a.
2009 PONTIAC G8
Jahntassa
Re: (ragingfish)
Post by Jahntassa »
Quote, originally posted by ragingfish »Try a line level converter, aka scosche fai-3a.Looking back over it..why isn't that in the sticky?
MichaelCArens
Re: (Jahntassa)
I did read the sticky however there was no information regarding the tweeters.I am going to attempt to create my own wiring harness this evening to avoid ruining anything.
