need part # for airbox!
savedbyzero
Post by savedbyzero »
Want to purchase a new intake hose incase i f' mine up while installing custom intake...any help?
THIS IS WHAT I DO...http://www.studiothisis.com
d_m_kolb
Re: need part # for airbox! (savedbyzero)
Post by d_m_kolb »
I can help but I'm confused on what your doing?
savedbyzero
Re: need part # for airbox! (d_m_kolb)
custom intake...might cut around the sensor in order to afix bracket to new pipe...or does the whole piece of tube that the MAF sensor is mounted on come out of both sides(i now it does form the S-tube to the sensor, but not sure about in to the airbox) if it does, then i can just use rubber hose and clamps to attach it. plus i can reinstall a stock airbox if i need to take it in for work and avoid being hassled by the shop for a void warranty...
savedbyzero
(bump to top)help me out here, guys!
savedbyzero
come on d-m-kolb! you're let me down here! got the number by chance? i've looked but no luck! i might try to call the aprts department tomorrow. hmmm. i'm a genious.
d_m_kolb
Post by d_m_kolb »
Take your intake tubing apart and see what it looks like and what peices come apart and which ones don't. I did this with mine and that way you'll know what you need and where to start.As for a part number for the filter I have a killer filter you should use for your custom CAI. Plus it's a new design that sucks in air from the top and not just the sides. MORE AIR FLOW!!!! I have the part # posted in my Custom CAI topic in the engine forum.
ragingfish
Post by ragingfish »
I know this thread is about two years old, but thought I'd throw this out there:DUCT, FRONT AIR INTAKE 88969117 31.09
2009 PONTIAC G8
scherry2
Re: need part # for airbox! (ragingfish)
Post by scherry2 »
better late than never. LOL
jjhendri
Post by jjhendri »
Hi Ragingfish is this really the part # for the stock airbox for the vibe gt. I hot an '03, and one of the clips broke off. Can't tell if I did or if it was done when it went in for service. The $31.09 posted was that the dealer's price?Quote, originally posted by ragingfish »I know this thread is about two years old, but thought I'd throw this out there:DUCT, FRONT AIR INTAKE 88969117 31.09jjhendri
scherry2
Re: need part # for airbox! (jjhendri)
Post by scherry2 »
no its not you need the lower housing which is #88969104 there was no price in my lists. you'll have to go to the dealer or gmpartsdirect.com which list it as;GM PART # 88969104 CATEGORY: All PACK QTY: 1CORE CHARGE: $0.00GM LIST: $88.55OUR PRICE: $52.48 or go to toyota and see how much cheaper it is there.
jjhendri
Re: need part # for airbox! (scherry2)
Post by jjhendri »
scherry2 thanks for the info will post the price compare of gm vs toyoQuote, originally posted by scherry2 »no its not you need the lower housing which is #88969104 there was no price in my lists. you'll have to go to the dealer or gmpartsdirect.com which list it as;GM PART # 88969104 CATEGORY: All PACK QTY: 1CORE CHARGE: $0.00GM LIST: $88.55OUR PRICE: $52.48 or go to toyota and see how much cheaper it is there.
