how to check amp for blown fuse(s)
vanman1
Post by vanman1 »
Changed my cd player with another factory unit. still no sound. Changed fuses at firewall for amp and for gauges fuse underneath dash. still no sound. Can you advise how to remove amp under the seat? how/where do you check the amp's fuses? I could pay someone but I want to learn how my Vibe works . Thanks to all responders. Dave
kevera
Re: how to check amp for blown fuse(s) (vanman1)
Post by kevera »
Hey Vanman.I saw your other post and was wondering,from what vehicle was the radio you replaced the original with.Was it from another vibe,matrix,or other gm model.
ragingfish
Post by ragingfish »
Amplifier has NO fuses, breakers, or other resettable devices on it. Removing it won't help you.I would recommend a dealer visit at this point...might be a wiring issue...
2009 PONTIAC G8
silvrhawk7
Post by silvrhawk7 »
Almost sounds like it could be one of those stereos that need to be interfaced with the engines computer. Does the Radio itself give any messages or codes??
In Memory, taken too early in a rear end collision
Sunrise: June 2006, Sunset: Jan 2015 :cry:
Miles 129,000
2006 Silver Mono, Base 4-Speed auto.
In Memory of Pontiac Motor Division 1926-2010
In Memory of the Pontiac Vibe 2002-2009
mcgusto82
Re: how to check amp for blown fuse(s) (silvrhawk7)
Post by mcgusto82 »
isn't the fuse labeled "cig" the radio fuse? Check that ifyou are getting no absolute power.
