Sent my car in today for it's 100k check up and it through a code a day after i set up apointment got my antifreeze, trany fluid etc changed plugs too and found out that i need a cat converter is why the car trough a codeQuestion is has anyone changed theres and if so which did you choose im going to run a high flow converter just wasnt sure if anyone else experinced any problem if they used a high flow cat?
Hey George, I had mine switched to a Magnaflow high flow cat (don't know part # though) about 1-1/2 yrs. ago w/no problems at all since. I had it replaced when I had my custom exhaust done.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
