Electric lift glass release?
mntn-biker
Post by mntn-biker »
I have a base model '03 Vibe w/o auto door locks. Was there an option for an electric liftglass release? I had a '92 Suburban at 1 time that had something like this.
2003 base model
ragingfish
Post by ragingfish »
it's part of the power lock package.
2009 PONTIAC G8
Jahntassa
Post by Jahntassa »
As raging said, part of the package. On the Vibe your options were power and no power, no in-between. If you want an electric release for your hatch glass, you're going to have to add the solenoid yourself (or have it installed, but aftermarket, not factory)
NascarXprt
Re: (Jahntassa)
Post by NascarXprt »
would that be the same for the doors, hatch, and windows?
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Jahntassa
Re: (NascarXprt)
Post by Jahntassa »
Quote, originally posted by NascarXprt »would that be the same for the doors, hatch, and windows?As far as what it would take? The hatch glass / hatch should only need solenoids. The windows would probably need a conversion kit (which they sell aftermarket), the doorlocks however you would need to pay a lot for, because the Vibe, like most Toyota designs, have cable based door locks, which are not easy to deal with.
kevera
Re: Electric lift glass release? (mntn-biker)
Post by kevera »
I did the power lock install on my vibe.I cheaped out and didn't order power locks when I bought the vibe.They have a kit for the cable type actuated systems like ours that are relativley cheap,I think I paid $130 for the whole kit.It was easy to install,took about 4 hours to run all the wires to all 4 doors.I'm not sure about the glass release but I would check this place out,if anyone would have it they would.But,you would have to install a kit to control the glass release,so I think it would be better to install a door lock kit while your at it.http://www.a1electric.com/index.htm
