Car key
Jack
Car key
Post by Jack »
I've just been to a local store where I wanted to make a duplicate key to my car. I was advised by the salesperson that probably the key has a special chip built-in and I have to get my dealer to make me a special key. In fact, he did make one duplicate key, but indeed, it did not work at all, I was not able to even open the door.So, I wonder, is there a special chip built-in inside the key--or any other device? I have Vibe base, no power package and no keyless entry.
MA-VIBE-FAN
Re: Car key (Jack)
Post by MA-VIBE-FAN »
No special chip in the Vibe Key. (Only Aztek, Bonneville, Grand Prix, Montana, and Firebird as far as Pontiac goes).
hoeboe
Re: Car key (Jack)
Post by hoeboe »
since the dealer cut the key wrong, i suggest taking it back to him and have him cut it properly. and test it before you leave. question. did he copy cut it or did he do it from the key tag number? if it was the key tag number that would be weird.
Chazb
Re: Car key (Jack)
Post by Chazb »
You should have gotten a number on your key ring when you bought your car,just take that number up to the dealership and you can order more key's.The key you had made should have worked .
vivianyorke
Re: Car key (Jack)
Post by vivianyorke »
I got a key cut at one place (Canadian Tire), went out to try it, and no, it didn't work. A few days later I went to another store (a locksmith shop) to try to get a key cut, and I told him what had happened. He suggested that it might have a "chip" in it... but, the key he cut worked perfectly!So... no, there is no chip, and just persevere with getting a copy made that will work!
Cheers!Vivian Yorke, Kingston, Ontario, CanadaSalsa Vibe, 5-speed, "Sport" and "Power" packages Vrooooom, Vrooooom
VibeSalsa
Re: Car key
Post by VibeSalsa »
Last month, I went to a specialized store to have a key cut on my Vibe. This store only sells locks, keys and other things like that. They have a full satisfaction garantee and usually, they do a very good job. The guy at this place put my key in a kind of analyser of key, cut the key and he give me the copy. It costs me 3.45 $ (CAN).I went outside to my vibe and the key was working very well. So, there isn't a chip built-in, if you don't have a good copy, you just have to go back to the place they have done this job and ask for a new copy that will work or have your money refunded...
2003 Base Vibe, Salsa, 5-speed, Power PackageLow pitch hornPic of my Vibe
NovaResource
Re: Car key (silverawd26)
Post by NovaResource »
I has a spare key cut at Home Depot the day I picked up the car. It works fine (ignition and doors). No chip.
30yr_old_fogey
Post by 30yr_old_fogey »
My two cents - I had one made at a local ACE hardware. At first, they couldn't match the blank because I said it was a Pontiac. After a second thought, I asked them to check the TOYOTA blanks - yep.So, it's a Toyota blank - FYI.
2003 VibeGT - AbyssNo Mods Yet
Vibe Rater
Post by Vibe Rater »
Vibe Key Cutting InformationTo duplicate a Pontiac Vibe key, use key blank p/n 88972631 and one of the key cutters in the accompanying chart. These key cutters are available from GM Dealer Equipment at 1.800.468.6657Supplier Function Part Number DescriptionIlco Hand Operated Code Cutting* Accessory Kit 74-MK1-P2674-MK1-TO-AE-01 Exacta Cutter & CaseKit - Pontiac VIBEIlco Machine Duplicating 74-045-110VAC Heavy Duty DuplicatorIlco Machine Duplicating and Code Cutting 74-029A-GM74-029A-TOY2 Combo Key Duplicator & Key Code Cutter Kit - Pontiac VIBEIlco Computerized Duplicating and Code Cutting 74-ULTRACODE Ultracode Code Cutter & DuplicatorCurtis Computerized Duplicating and Code Cutting 425-9100021 Curtis PC+Available through GM Dealer Equipment1-800-GM-TOOLS (1-800-468-6657)* (Numerous Exacta Kits available for all GM products)This information available at this link - from another thread on this board.http://service.gm.com/gmtechlink/images ... ml#story17
ken
Re: Car key (Vibe Rater)
Post by ken »
got mine cut at a local home depot. had to do it a second time though because they had apparently used the wrong blank.
Sub-Vibe-R
Re: Car key (ken)
Post by Sub-Vibe-R »
I went to Home Depot as well. The guy amde a copy of mine, no chip and it works perfectly.The guy only had hard time to find out to good key, as he was locking for a GM key and this is a Toyota one.
