2004 Vibe GT premium radio harnesses
smoozdog
Post by smoozdog »
Can anyone tell me exactly what the other wiring harness goes to (not the 24-pin) with the premium (Moon and Tunes) head unit? I am assuming it goes to a separate amp(?). If anyone has wiring schematics on this, please post them. Thanks
Attached files stereo.pdf (204.8 KB)
Jahntassa
Post by Jahntassa »
It's the amplifier turn-on wire. It should only have one wire on the plug. You need to put 12v to that to turn on the M&T amplifier.
ragingfish
Post by ragingfish »
Quote, originally posted by Jahntassa »It's the amplifier turn-on wire. It should only have one wire on the plug. You need to put 12v to that to turn on the M&T amplifier.You sure?In my 03 it was "mute control." Remote amp signal was B3 in the main harness...Quote, originally posted by smoozdog »Can anyone tell me exactly what the other wiring harness goes to (not the 24-pin) with the premium (Moon and Tunes) head unit? I am assuming it goes to a separate amp(?). If anyone has wiring schematics on this, please post them. ThanksThe info you need should be in this thread:http://forums.genvibe.com/zerothread?id=14275
2009 PONTIAC G8
smoozdog
Re: (ragingfish)
Post by smoozdog »
Ok, thanks guys for the replies. It's not something I need (if driving the speakers from an aftermarket deck) then. Now I need to find some 4ohm speakers to compliment it. I attached the pics I took anyways. Thanks again.
smoozdog
Re: (smoozdog)
Post by smoozdog »
Oh yeah, do any of you guys know where this amp is located? Thanks
cruzin
Post by cruzin »
Under the front passenger seat
Jahntassa
Re: (ragingfish)
Post by Jahntassa »
Quote, originally posted by ragingfish »You sure?Nope. That was an off-the-cuff post.
