welcome to genvibeQuote, originally posted by dereknicholas »Does anyone out there have any info on changing out the internal reading lamp on the moon and tunes model?If you mean how to replace a burned out map light bulb in the moonroof control assembly, then first remove the one screw that you see in the cover. Then, roll your fingertips under the cover and pull it off. The whole plastic cover, gray and clear, comes off as one piece. From there it should be easy enough to swap the bulb.
http://forums.genvibe.com/zerothread?id=12225 is an index of interior light bulbs, which says that that bulb is a "1895", looks like a bayonet type, 1/4 turn to put in/take out
