left my roof popped up and it rained med hard all day....
bagwell
Post by bagwell »
no water on the seats....but when I made a right turn, water dripped down (streamed in) from the front upper left roof where the headliner meets the plastic piece by the windshield. Has anyone had this happen? did water get inside the body of the car???
ragingfish
Post by ragingfish »
if you mean it came from the a-pillar...one of the roof drains goes through there, so it could be clogged. otherwise, i can't see your seats being dry but the inner body being soaked.
2009 PONTIAC G8
CAN-AWD-VIBE
Re: left my roof popped up and it rained med hard all day.... (bagwell)
Post by CAN-AWD-VIBE »
Quote, originally posted by bagwell »no water on the seats....but when I made a right turn, water dripped down (streamed in) from the front upper left roof where the headliner meets the plastic piece by the windshield. Has anyone had this happen? did water get inside the body of the car???i guess the water would follow the sunroof molding down inside the roof... check your dome light and roof switch for water! Even if a little water gets on there you will be fine, i have made that mistake before, wide open, with hail. That was fun.
mcgusto82
Re: left my roof popped up and it rained med hard all day.... (CAN-AWD-VIBE)
Post by mcgusto82 »
once i left the sunroof open and it rained. My seats were also dry, but my carpet was dripping wet. So, check that.if it is, you gotta pull out both front seats, t pull up he carpet and dry it. Otherwise. it's goin to be one musky vibe.
bagwell
Re: (ragingfish)
Post by bagwell »
Quote, originally posted by ragingfish »if you mean it came from the a-pillar...one of the roof drains goes through there, so it could be clogged. otherwise, i can't see your seats being dry but the inner body being soaked.so how do you unclog the roof drain(s)...where are they located?
