Quote, originally posted by jimincalif »1. My house is already wired for cable where the TVs are. Does the satellite hook into the existing cable wiring? Or is new coax needed to each TV location?Unfortunately, there probably isn't a straight forward answer. It is possible to use the existing cabling depending how you're having things run, what kind of cable already exists, etc.Quote »3. They tell us there are two receivers that support 4 TVs, where do these go? At the TVs themselves? In the attic?The simple answer is that the receivers go at each individual TV. The answer isn't quite as simple if you get one of the receivers that can be used for 2 TVs (the 622). I don't have Dish, but have done plenty of reading. With these receivers, you basically have a coax coming into the house and plugging into the receiver at one TV. Then coax goes out of the receiver and runs to a second TV in another location. So for that second TV, you actually don't have a receiver in that room. Quote »4. Do we have to have a separate tuner box at each TV or can a TV with an HD tuner built in just connect to the coax and use the TV tuner? What about non-HD TVs, do they need a box?I somewhat answered that question above. Again, the short general answer is that you'll need a receiver at each TV. There are still some exceptions in addition to what I covered above though. Some TVs allow the use of a cable card that you can get from your cable company so you don't need a receiver for that TV. I don't believe this works with any satellite companies.The built in tuner won't really do anything for you in terms of satellite. What it does allow however is the reception of the network stations for absolutely free, assuming you can get a signal from your location. By simply hooking up an antenna (possibly as simple as "rabbit ears"), and hooking that up to your TV tuner, you can pull in NBC, ABC, etc, again assuming you can pull in the signals. You can do this without even getting satellite. If you get satellite, you should also be able to hook an antenna to get the OTA (over the air) stations via your satellite receiver, and also get the guide data.You can use this site to determine how far you are from the local towers, and their direction:
http://www.antennaweb.org/aw/Welcome.aspx If you are close with a clear line of sight, you can probably get by with a simple set-top antenna such as the Zenith Silver Sensor. If you're further away, you might need an antenna in your attic or on your roof. My OTA antenna is mounted right to my dish on the roof, and I pull the stations in crystal clear from over 40 miles away.
