Hi there,Where can i get hubcentric rings in and around GTA area? I recently got a set of 15" multifit rims from Canadiantire about a month ago and just found out that the bore diameter of the hub and centrebore diameter of the rims do not match and need hubcentric rings for a snug fit .I will be grateful if anyone would give me some information as to where these are availabe in GTA .
i did a quick search about 2 years ago when i got the rims for my car...just in case i would ever need any.burlington tire can help you out...http://www.burlingtontire.com/
Thanks Tom , i appreciate that , would you happen to know of any in the east end . I went to Canadiantire today and the parts guy suggested i go to Wheels Direct located in McCowan and Sheppard . Will try there and if not then i will look up the one in Burlingtion.Btw what is the bore diameter of the vibe , is it 54.1 mm ??
Quote, originally posted by dennisdrive »Thanks Tom , i appreciate that , would you happen to know of any in the east end . I went to Canadiantire today and the parts guy suggested i go to Wheels Direct located in McCowan and Sheppard . Will try there and if not then i will look up the one in Burlingtion.Btw what is the bore diameter of the vibe , is it 54.1 mm ??no problem...i'm orginally from scarborough so i'll ask some friends out there who they recommend...i have the bore diam. written down in my garage at home (at work now)...54.1 sounds familiar but i'll let you know later
i don't see why they wouldn't fit?But there are others on here that know more than i do wrt that stuff.i looked all over my garage workbench for that paper with the measurements i took...couldn't find it 54.1 sounds vaguely familiar though...Left a message with friend in Scarb...hopefully have info for you soon.
The reason i asked the question was becoz CT had ordered 15"OE rims designed for Matrix . Good news is that i got the rims changed under warranty , the switched the multi fit rims for OE ones . And the vibe drives much smoother and less vibration felt in the steering wheel .Thanks for your suggestions .Have a nice holiday and warm X-mas .
