i'm planning on upgrading the radio in my friends 2005 vibe (basic stero, no moons/tunes). i just want to make sure i have all things needed to do this, and also need some info/advice from you guys/girls.- new headunit (single din)- antenna adapter- wire harness- radio cage/kitwhere can i purchase the antenna adapter, wire harness, radio cage/kit? are there model numbers? if so, what are they?i tried to search as best i could, and came up with the stuff at walmart isnt good. and to stick with metra products. any info and advice for removing the stock headunit and just tips to help the install go smoothly would be greatly appreciated. thank you.
