last gear
keithvibe
last gear
Post by keithvibe »
Being it have been getting colder around here lately I have noticed that when I start the vibe let it warm up for a few mins then start to drive the transmission will wait for a higher speed to shift into overdrive. I.E. if the car is warm the trans will shift into the last gear at or around 40mph. If the car is cold it will shift into the last gear at or around 50-55mph. Anyone else experience this as well?
joey116
Re: last gear (keithvibe)
Post by joey116 »
I know some Toyota models do this by design, I imagine the Vibe is the same.
Digger
Post by Digger »
Yep. It will not shift into higher gear untill the oil and/or cat. is warmed. I sometimes go a mile before it shifts in to OD if it is real cold out. That is one of the reasons your MPG goes down also.
WaveAction
Post by WaveAction »
is this only for auto? or both auto and manual
Re: (WaveblueVibe)
The transmission wouldn't prevent you from moving the shifter into the higher gears if the engine is cold... So, this is for the automatic only.
WaveAction
whew..glad i dont gotta worry about that then=)
keithvibe
Re: (WaveblueVibe)
Post by keithvibe »
lol silly boy... As is with the awd the gas milage is low enough this just adds to the reasoning to get an automatic car starter
dog paw
Post by dog paw »
Most GM vehicles will hold the clutch converter off till 160 deg engine temp Thats prolly what you are thinking is 4th gear
A running apology for misspells and general butchering of the Kings English
