as stated above will the throttle body spacer for a 2004 celica 1zz fit on a 2004 base vibe auto? any help would be appreciated need to know soon friend has one for sale and if it will wokr im buying it before he puts in on ebay
Not sure, but I have a Helix Power Tower Plus, Part# 97185 2000-2004 Toyota 1.8L 1ZZFE that I'll sell you. I bought it for my 05, but it doesn't fit, the DBW throttle body is smaller, so this has never been used.
Don't listen to Sunny. He does not have one so he cannot offer a real opinion on the TB spacer for the Vibe. I can guarantee you will feel a nice increase in torque at the low and midrange rpm's. I and everyone else that has tried it has had the same results.It will fit on the stock intake without any modification. If you have a SR you might be OK for fitment. Just make sure you have at least 2" of space to spare between your cone filter and your fuse box. If you have a CAI you will be required to cut off 1" of your intake at the TB end for it to fit.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
I bought one a while ago, but sold it once i got a cai. I noticed a difference, same as bluecrush did. Its not going to make it like a supercharger or anything but its there.
I have one on my car as well and it works well. Every little bit helps add it all up and it will make a big difference. Next on deck for me is suspention, it is on the way from Never enuff.
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
thanks guys. hey 4azdmunky how much do you want for the one you have? I live in eastern ky the zip here is 41501 if you can give me an estimate of what you would need including shipping i might just buy the one off you.
