Battery Removal
Katscan
Battery Removal
Post by Katscan »
The other day I had to change my driver side headlamp and thus I had to remove the battery. My question is, when I removed the positive terminal there was all this white powdery crap all around it. Is this something I should be concerned about? What the heck is it!?
djb383
Re: Battery Removal (Katscan)
Post by djb383 »
Clean it good and apply Vaseline to the terminal and clamp.
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
Raven
Post by Raven »
You can clean it with a paste of baking soda to neutralize the acid, rinse and apply di-electric grease.
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
its corrosionwire brush the white stuff and the terminalsapply battery terminal protector
Digger
Re: (CAN-AWD-VIBE)
Post by Digger »
It is also the first sign of a weak battery.
Ol' Timer
Re: (CAN-AWD-VIBE)
Post by Ol' Timer »
Quote, originally posted by CAN-AWD-VIBE »its corrosionwire brush the white stuff and the terminalsapply battery terminal protectorQuote, originally posted by Digger »It is also the first sign of a weak battery. I'm going with CAN-AWD-VIBE on this one. The white stuff is nothing more than corrosion. BUT, if not cleaned up. Sooner(or later) if will eventually be another factor that causes battery failure.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels2002 Snap Orange Beetle - Auto - Turbo
Katscan
Re: (Ol' Timer)
Post by Katscan »
Well when the weather clears up Im gonna go get that taken care of. And just to make sure, you remove the positive 1st and when putting it back together the positive goes on last.....is this correct?
2002sportside
Re: (Katscan)
Post by 2002sportside »
Remove the negative first, and put it back on last.
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
ragingfish
Post by ragingfish »
In some cases it could be a sign of a leaky battery...vapor leak perhaps...next time you're at the dealer I'd mention it to them...but don't make a special trip for it...
2009 PONTIAC G8
